Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Bending red lines
I have bending red lines, any help out there?
  • JVC Master
  • 8,617 Answers
Your convergence Ics and convergence resistors need replacing. You can get the convergence ICs stk392-110 and the resitor kit for a JVC at the following link with free instalation instructions.
Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 04, 2008
My break lines are broken and need to be replaced from the left side of car from thje middle to the rear
YOU HAVE TO GO BY AUTO PARTS STORE BUY NEW METAL BRAKE LINES AND YOU NEED A TUBE BENDER BEND CORRECT SHAPES DONT CRIMP BRAKE LINE OR DAMAGE BRAKE LINE BY OVER BENDING BECAUSE YOU WILL HAVE RESTRICTION IN BRAKE LINES IF BEND TOO MUCH.
Nov 05, 2011 | Cars & Trucks
I need to feed the line back into the holes on the craftsman 17' 25cc weed trimmer. I dont know how to remove the line holder to replace
Although it is called dual line, only one line is used - except that you use both ends of the line. Cut off as much line as you think the spool will hold. Put the two ends together to find the center of the line. Some trimmers have holes to thread the lines through and others have a place to hook the bend at the middle of the line. if yours has threading holes, thread one end of the line through each hole and then pull on both ends until the bend of the center of the line won't allow any more slack. If your trimmer has the place to hook the bend, hook there and start winding the lines in the direction shown on the spool. Be sure one line is on one half of the spool and the other line on the other half. Wind both lines at the same time as smoothly as you can. When the spool is full, insert the loose ends through the trimmer head, insert the spool and pull on the strings. Hope this helps Tim
Here is a site that can help if I did not understand your question correctly:
http://www.ehow.com/how_7872475_replace-craftsman-25cc-line-trimmer.html
Apr 10, 2011 | Craftsman 25cc Gas Line Trimmer
Where is the fuel filter located? I look under the truck n can't find it.
Look under the passenger side, the exhaust comes down from the manifold and bends at the frame. You'll see between the exhaust and the frame a heat shield. Remove the two 13mm bolts on the frame and bend the heat shield downward, it will be able to bend back into position without breaking. Then there are 2 10mm nuts holding a plastic cover, behind that is the fuel filter. Ford has many different methods for clips on fuel lines, you may need a removal tool, and/or new plastic clips, which you'll find at the dealer. If there is a red or blue plastic clip, be careful, they are part of the fuel lines and not servicable.
Aug 08, 2009 | 2004 Ford Explorer
I have a 84 GMC 3/4 ton, 5.0 liter engine. What tools would i need to replace a transmission line? It's a metal line, it looks like it has a couple of bends in it.
Aside from some wrench's you will need to be able to bend the line. If you don't have or can't borrow a tubing bender, I've had good luck using a large bolt with two flat washers. Clamp the bolt in a vise, set the line between the washers and snug up the nut so the line just moves. Bend the line slowly and it won;t collapse. Keep your hands close to where you want the bend to be.It's the same as steel brake line, just make sure that when you get a new line at the parts store that the fittings will work on your trans or you will need a double flare kit to change the fittings. Take the old line with you, and they should be able to use fittings there to get you set up. Hope this helps.
Jul 03, 2009 | 1998 GMC Sierra
I had a convergence problem on my Mitsubishi WS-65711 where the red and blue was bending outward from center giving a 3D effect. I replaced the STK pack and the red and blue look good now, but now the...
green is base line center and some times is not adjustable
.Did you replace both convergance chips?
also there are 6 , 2.2 ohm res that get out of
tolarance. check them first
Jun 30, 2009 | Mitsubishi WS-65511 65" Rear Projection...
RED LIGHTS COME ON AFTER I CLEANED THE GRIDS
hi.....
u wud have to take a pair of needle-nose pliers and rip out the metal blade at the bottom where the spark is occurring and fold it back against itself so that it is no longer "seated" into the bottom of the unit where the sparking is occurring
take care to bend the parts back in line with the blade so that lined up and could be removed and replaced into the unit without scraping anything. When u put it back in, there ll be one last "spark" or probably a couple...... and after that i shud work just fine......
thank youhave a nice day good luck
Jun 02, 2009 | Sharper Image Hybrid GP (SI724) Air...
Information on brake lines from master cylinder
Manufacturers have been putting that type line covering on for years. Though it does offer some scuff protection for the line, personally I believe that it also holds salt and other debris, making lines somewhat more prone to rust and corrosion. I would not concern myself with that feature or lack of lit in a replacement line. The extra bend in the line is another story... It is a good idea to put some sort of extra bend in the line. The bend serves to deaden vibration and resulting stress fractures which can form right at the fittings.Be careful when bending lines not to crimp them in any way. Keep in mind when routing lines that it is most important to support them to avoid vibration and keep them away from linkage and suspension components which move during normal driving. I generally slip a piece of rubber hose around any point where the line crosses any "edge" that could chafe through the line and cause failure.
good luck
Jan 31, 2009 | 1999 Oldsmobile Eighty Eight
I have a projection tv that has a yellow bending line
It sounds like you need the convergence amplifiers replaced. Are you an expert solderer? If not, I would have a qualified technician repair this. Most places here in Alabama will fix it between $200-$300.
Jan 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Red line runs from middle of screen to right bottom and bends in middle
look the only thing u can do is have someone put the parts in for u the parts alone is 40-$ 60.00 and maybe $ 150 in labor that is all u should have to pay. that is what i would charge a customer to repair there tv set and it can be service right there in your home.i hope this helps marty
Oct 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
42 " Panasonic
have you ck 2.2 ohm resistors, try looking near ics ck all low ohm resistors.this can cause your problem.
Oct 28, 2007 | Panasonic PT-47WX53 47" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
