Question about Troy-Bilt Garden
Where is oil drain for honda engine on troy mower?
  • 710 Answers
I don't believe Troy-Bilt is any different than other chainsaws. There is no drain plug. You just turn it over and pour it out through the filler cap.
I did look at a diagram for Troy-Bilt and there was no drain.
Hope this helps
Handie Andie
Posted on Mar 25, 2011
  • Handie Andie
    Handie Andie Mar 25, 2011
    I'm sorry, I misunderstood your question. I will check out mowers.
    Handie Andie
  • Handie Andie
    It is a bolt plug on the opposite side of the oil filler cap at the bottom of the engine.
    Handie Andie
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
What Oil do I put in a Troy Bilt xp series mower
They recommend using only SAE 30 oil or 5W-30 if you choose to use synthetic. Be careful. Most smaller mower engines only require about 20-21 oz. The Honda engine may use more. See gauge on side of oil bottle.
Jul 05, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I own a troy built self propelled mower with a Honda GC160 engine. I'm wanting to drain the oil and am looking at the engine where the manual says there is an oil drain plug, but there is no plug. Can you...
it's on the same side as the muffler near the bottom of the engine. carefull with the oil if you run it before you change the oil as it will be HOT!!!...good luck
Apr 06, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Can't find owners manual for troy built 21''. How do I drain oil from engine.
Not knowing what model number mower you have, there are a couple of possibilities for draining the oil.
Number one: You can tilt the mower back on the handle bar and look at the bottom side of the engine for a drain plug that is easily accessible and unobstructed so that the oil would drain straight into a container with the mower elevated on something high enough to get the container under it. Loosen the plug then put it up on the blocks, saw horses or whatever you are using, get your catch container under it and remove the plug.
Number Two: Start the engine and warm it up for a few minutes to make the oil flow easier. Set it up on a work bench with the oil dipstick tube toward the outer edge of the bench. Line up a catch container on the floor below it and tip the mower over on its side and pour the oil out the dipstick tube into the container. Just use caution not to touch any hot parts of the engine when lifting it up. This is the way Briggs & Stratton recommends changing the oil in their engines which do no have an accessible drain plug.
Oct 25, 2009 | Troy Garden
Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Apr 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Garden Logo
169 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
