Question about Dimplex OFC2000TI Heater
Hi, I don't know what the reset switch on my dimplex ofc2000ti looks like, anyone any ideas? Power to unit but not heating up, all connections inside fine. Hopefully it overloaded and tripped.
    Brigadier General:
  • 4,736 Answers
Turn the Master On/Off Switch to OFF and unplug the unit from the wall receptacle. Leave it unplugged for 12 - 15 minutes. That should give it enough time to reset itself. Then plug it back in and give it a try. Also, make sure that the wall receptacle is working properly and hasn't tripped the circuit breaker in your home's circuit breaker panel. If it did, something is seriously wrong electrically, with the heater.
Hope this helps you solve the problem. Please don't forget to rate my response to your question.
Thanks!
Posted on Mar 26, 2011
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
Dimplex DS3311 switch is overheating and melting. What to do?
How long does it take before the switch melts?
You could try retrofitting a switch from the hardware store that has a higher watt/amp rating...
Jan 16, 2013 | Dimplex Heating & Cooling
The LCD (24 hour timer) is blank so the heater wont work
There is nothing you can do, turn on your oven if electric, or if gas open a window 4 inches and dont sleep with a gas burner running.
Oct 25, 2012 | Dimplex OFC2000TI Heater
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
Just purchased a dimplex DS5629 electric stove. Plugged it in, but NO HEAT and NO BLOWER. Dimplex is closed for the weekend. NOW WHAT???
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Apr 01, 2011 | Dimplex DS5629 Electric Heater
Why does my dimplex model bf8000st fan and heat turn off after 2 or 3 minutes? the flame lights keep working, just no fan or heat.
"Resetting the Temperature Cutoff Switch
This unit is equipped with a thermostat which controls the temperature
of the room by turning the heater on and off. The heater is protected
with a safety device to prevent overheating. Should the heater
overheat, an automatic cut out will turn the heater off and it will not
come back on without being reset. It can be reset by switching the
Main On/Off Switch to off and waiting five (5) minutes before switching
the unit back on."
http://dimplex.com/cms/publications/7208680300r03_EN.pdf
Dec 13, 2010 | Heating & Cooling
Dimplex DS5804 remote unit
Call Dimplex : 1-800-668-6663 ext# 358 They will be gla to help and send parts if needed.
Dec 09, 2008 | Dimplex Compact Electric Flame Stove...
I have a dimplex electralog model cs4416 and it is still heating but will not blow the heat out what can i do
I beleive the heater and fan switch are a dual unit. Mine has a AUOne ST 360. I pulled the part outand it the copper is very pitted and corroded. The problem I have found is that this switch is made in China and I have had no luck finding a US distributor.Electralog/Dimplex... has an toll free number but it is hard to get through. 1-888-346-7539. If anyone gets through on thier problem, please ask about price and delivery and where to order. I would love to see this posted.
Nov 22, 2008 | Heating & Cooling
Dimplex OFC2000TI Heater Logo
610 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
David Burbee
David Burbee
Oloyede Monsuru
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
