Question about Samsung RS2630SH Side by Side Refrigerator
Fridge not cold
Temp on fridge not working ie fridge not cooling food
  • 8 more comments
  • bevrleyburto Aug 17, 2008
    fridge doesnt cool and makes bubbling noises when switched off and on again
  • azee786 Aug 30, 2008
    refrigrator is not cooling enough. and the door alarm coming up..
  • berhthabritn Oct 06, 2008
    My side by side freezer works fine but the fridge is not getting cold at all
    We have to defrost the coils cause they freeze up about once a week. We replaces the thermastat and the censor and it still does it. I recommend not getting a maytag side by side
  • bambollanna Feb 18, 2009
    first there was this loud high pitched noise from the freezer, so i googled and it said to turn the temp off for a couple of minutes then turn back up and the noise should stop and it did, but now the fridge is not cold at all and its almost on high, any suggestions?
  • ricardos Feb 18, 2009
    I have a problem with my 7 year Samsung SRS579NP lately. The fridge is not cold. Just notice that can't hear any noise from the motor at all.
    Turned off and turn on the switch then , motor runs again but after few hours stopped again.
    Please help.
  • Anonymous Feb 22, 2009
    Kenmore side by side- freezer seems fine but fridge side is warm.
  • Anonymous Feb 23, 2009
    REFRIGERATOR IS NOT COLD (SAMSUNG MODEL#RS2630SH)
  • Anonymous Feb 24, 2009
    Side by side fridge rs2556 SH stop cooling, back panel inside covered with ice
  • Anonymous Mar 03, 2009
    no lights on control panel and not cooling
  • RAVI100848 May 23, 2009
    Refrigerator and Freezer not cooling
    Please email at ravi100848@yahoo.com
I think that I have a solution. Refridgerator side not cooling.
I read in the blogs that holding down the top two bottons(power cool & fridge) at the same time resets the refridgerator control panel.
I may have caused the problem by leaving the door open. If my above solution does not work, then I will defrost the frefrigerator just in case the coils are froze up. It works with my air conditioner.
Ed
Posted on Feb 23, 2009
I have a side by side fredzer and refrigerator digetal thermometer . The freezer temperature will not go below 54 or 53 and the refrigerator states at 43or 45.
Posted on Aug 29, 2008
    Problem Solver:
  • 5 Answers
There could be a multple amount of reason why fridge is not cooling but here are a few easy tests. But first, if fridge door is keep open for long period of time or is constantly being opened and closed this releases alot of the cold air and also cause the compressor to work over time especially in the these hot summer times. as soon as you find item you want close the door save the compressor and electricity.T2. checking the gasket on your fridge door, a old, dirty, or damaged door gasket can cause cool air to escape and small critters to get in. to test to see if the gasket is faulty simpl get a dollar open the fridge door place the dollar on the top wall where the gasket meets the fridge close the door the door onto the dollar now get a few gentle tuggs if it comes out easy the gasket is not sealing properly and should be replaced. if it gives a liitle resistance then the top part is good now check on the bottom and rremaning sides if resistance is felt its good.
Posted on Aug 10, 2008
Top Freezer not freezer, fridge not cooling
It is probably the thermostat but i would have someone look at it
Apr 16, 2014 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
The temp on the door reads very cold, ie. -10 freezer, 34ish fridge. When you open either, there is melting food in the freezer and cool food in the fridge. Unplug it and plug it back in, and the temps...
Sounds like you have a defective thermistor....The problem is there are 4 that deal with Fridge and Freezer compartments...There are tests that you can run from the display panel. You will not hurt anything by trying the tests...It is too difficult to explain the tests but here is a link a pdf for the RB215 that will help you if you or someone can follow directions...
Most servicers don't have a clue about this stuff....bummer
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Mar 08, 2010 | Samsung RB2155SH Bottom Freezer...
The refrigerator is not cold only cool. the freezer door got accidentally left ajar and got ice build-up on the food. Ever since that the refrigerator portion is only slightly cool not cold. I moved the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. The ice may have also stopped up this opening blocking the air flow.Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Refrigerators
My freezer is working fine but by refrigerator is not working. how can that be with a maytag side by side?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
The fridge and freezer stopped cooling. we defrosted it. There was frost in the freezer. Before that the ice on the door had stopped and now it works too.
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signaled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
I bought a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
May 18, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Samsung RS2630SH Side by Side Refrigerator Logo
766 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
