Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Cant turn printer off none of the buttons work ink is low will this cause a problem cant fax or copy
  • HP Master
  • 1,679 Answers
Ink low issue or message should not cause the printer to freeze.
You can disconnect the power cord from back of the printer ( while printer is on ) and connect it back after 10 seconds. Turn on the printer.
It should work fine.
Regards,
Ron
Posted on Mar 25, 2011
I installed a new black cartridge and now it is not printing. I need the installation guide for allignment
Please follow below instruction. Otherwise, visit this link. Link
We hope we have provided you a solution to your problem.
Thank you.
The Canon Pixma Mp160 is an all-in-one printer, scannermag-glass_10x10.gif and fax machine. Replacing the cartridge in the printer requires little effort. Make sure to use the correct replacement cartridges for your MP160; installing the wrong cartridge type could prevent your printer from working or cause it to fail. Use caution to prevent ink spilling or dripping on you.
Step 1 Identify the cartridge that requires replacement. Press the "Copy" button to display the ink level. "BLK" indicates your black ink cartridge; "COL" indicates your color cartridge. If the display is only one bar (or none), then the cartridge should be replaced.
Step 2 Open the top compartment (scan lid) on your Canon printer. Pull back the compartment support legs to hold it open.
Step 3 Put on gloves, and then push the cartridge down to unlock it. Pull it toward you to remove it from the printer.
Step 4 Remove the tape strip from the replacement ink cartridge. Insert the new ink cartridge (black on the left, color on the right) at an angle, with the gold circuit facing down and towards the front of the printer. Push the cartridge up to lock it in place.
Step 5 Repeat the process if you are replacing multiple cartridges. Close the scan lid when you are finished. If the "Low Ink" warning does not go away, then turn the printer off, wait a few minutes and turn it on again.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
shows empty cartridges but it will printing.
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cant receive faxes
plz check all cables properl there might be damaged one ... then check you fax machine ink ..if none seems to be the problem the get it once serviced it will get back on working
Aug 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MY HP PHOTOSMART 3110 ALL-IN-ONE PRINTER FAX SCANNER COPIER IS HAVING AN INK SYSTEM FAILER AND IS UNABLE TO COPY,RECEIVE,FAXES, OR PRINT.
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx
Jul 09, 2009 | Office Equipment & Supplies
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Document in ADF error when faxing
  1. This problem is caused by refilling your ink cartridge but there is a solution
  2. When the ink is low or the computer thinks the ink is low the sheet feeder will not work
  3. You will notice that the in use/memory light is on
  4. The memory has a report it needs to print but does not want to print it without ink
  5. To print the report anyway do the following:
  6. Press the <FAX> button to enter the Fax menu.
  7. Press the <Menu> button. [FAX SETTINGS] is displayed
  8. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  9. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK. Select Yes. make sure there is paper in the printer.
  10. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
Aug 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
"waiting for report" /won't copy
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
Apr 22, 2008 | Canon PIXMA MX310 All-In-One Printer
SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Oct 26, 2007 | HP Photosmart 3310 Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
