Question about Whirlpool Washing Machines
Machine does not stop filling with water and over flowed nor did it start washing
  • Whirlpool Master
  • 3,463 Answers
It sounds like the water level sensor switch is not functioning, until it does operate, then the washer will not ncommence it's programme.
I cannot help you further without knowing the make and model of washer, can you please confirm this ?
Thyankyou.
Posted on Mar 25, 2011
Sometimes water won't flow on certain timer settings. And sometimes starts, then stops.
i would go heavy on the deoxit D5
https://www.google.co.uk/search?q=deoxit+D5&ie=utf-8&oe=utf-8&gws_rd=cr&ei=IhJAVZevEILsat3agcAD
i think your timer control switch
has carbonized contacts...
so perhaps the contactors are blasted a bit
either this or look for a new program control
Apr 28, 2015 | Washing Machines
My whirlpool washing machine wont stop filling with water after the wash cycle
your post is vauge
does it over flow
you mean it wont stop the rinse cycle
did you check it for a reset
do a factory reset
the machine will fill with water until the flow sensor and level has filled
so check and clean the machine
i find a couple of dishwasher cleaner tabs thru it first will clean all the flows and pipes and use a 60 deg long wash for whites
i think all the electro is aok so must be dirt
Sep 24, 2014 | Whirlpool Washing Machines
Water doesnt stop when filling washing machine
There should be a "fill control" on the panel of the achine that lets you set the fill limit for wash loads ranging from small to large. Obviously, your fill control is not working
Oct 09, 2012 | Washing Machines
Water won't stop filling
If the water still flows in when the machine is off the inlet solenoid is faulty, if when you push start it fills and keeps filling then the problem will be with either the electronics or the pressure switch.
You really need to get someone who has experience with whirlpool machines to look at it for you.
Mar 08, 2012 | Whirlpool Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
Hi there my hotpoint washing machinewma 54 fills up without the machine being on
Hello. your fill valve is faulty and needs to be replaced.
here is how the fill valve is supposed to work:
The fill valve--which is about the size of a coffee cup--is sometimes also called a "water inlet valve." It controls the entry of hot and cold water into the machine. The valve has three major components:
  • A hot-water solenoid
  • A cold-water solenoid
  • A mixing valve body
The inlet valve has three hoses connected to it, for :
  • The hot water from the house
  • The cold water from the house
  • The water directed into the washing machine's inner tub (either hot or cold, or both) to fill it with water
When electricity flows to one or both solenoids, water flows through the valve into the washing machine's inner tub. When the electricity stops, the water also stops.
Aug 21, 2009 | Washing Machines
Washer continures to fill up with water to the point of over flowing and won't start a cycle
is most probably the inlet valve at the rear of the machine where the inlet hose connects too.
May have to remove the rear panel to gain access to valve, it may just be a wire has come off
Hope this helps
May 22, 2009 | Zanussi ZWF1430W Front Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
47 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
