Question about Insignia Cameras
Washed my battery charger by accident and lost the wires for the computer can i get new and how much do they cost?
  • 356 Answers
It will depend on your exact model for costs, but Insignia is a Best Buy brand, so they should have the extra accessories you need.
If the cable you mentioned was the USB one, most models use a USB to microUSB cable which you can get cheaply at almost any electronics store.
Posted on Mar 25, 2011
I accidently got my battery charger Model #HP8204B 24VDC/4A wet I have replaced the internal fuse several times only to have it blow again and again?
The water caused a short and burnt out wires. Those wires are creating a dead short to earth. You need a new charger and the knowledge not to let it get wet again.
Sep 29, 2016 | Health & Beauty
I have a Kensington universal laptop charger for my Dell Inspiron. I have lost the adapter plug. Can I purchase, just the plug, rather than purchasing a new charger?
WELL AT DELL SERVICE CENTER YOU MAY HAVE TO BUY A NEW COMPLETE CHARGER BUT THAT WILL BE COSTLY INSTEAD YOU CAN MAKE YOUR OWN PLUG .ALL YOU NEED IS JUST A SET OF WIRE AND A THREE PI N PLUG.
Jul 21, 2011 | Computers & Internet
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
How do you change battery on scooter x360
You probably have a 24 volt or 36 volt system. For each 12 volts, you will need 1 battery. Thus, you will need 2-3 batteries. The batteries are located between the footrest in the middle. Some have an access panel. If your model does not have that panel, then you have to remove the seat and plastic body, a very time consuming and annoying process. You may even have to remove the steering stem. Pull out the batteries, TAKE SEVERAL PICTURES of the wiring so you can put it back together exactly the same way. The wires have to be in series. If you screw this up, best case it won't charge properly, worst case you can overheat and damage the batteries, even causing them to explode and cause a fire in extreme cases. The old wires may be soldered on. Just snip them off and install new connectors that you can find at walmart, radio shack, or any automotive store. The manufacturer should have left a little extra wire to allow for this. If not, you may have to remove the solder with a soldering gun and reuse the existing connectors, or run new wire. You probably need 12V7AH, 12V8AH, 12V10AH, or 12V12AH SLA batteries(SLA means sealed lead acid, V means Volts, and AH means Amp Hour). It should be stamped on the side of the battery. 10AH and 12AH are the most common. They should cost about $25-$40 each depending on the supplier and size of the battery. The higher the AH, the more expensive the battery. Once you've changed the batteries, charge them completely before using it. FYI: Always fully recharge the batteries after you deplete them. Letting them sit discharged will drastically shorten their life or even ruin brand new batteries. Also recharge the batteries every couple of weeks, even if you aren't using the scooter. They gradually discharge when sitting. If you keep the batteries charged, you should expect about 1.5 - 2 years out of them for average use. Hope this helps. www.solanocycle.com
Jun 19, 2010 | Electric X Treme X 360 Scooter
Plugged in & not charging with new battery
Laptop not charging
if you have a brand new battery and it is not charging, check the charger you may have to replace the plug on both sides, check the cables.
you can take the charger to a TV repair shop and tell them to check it and see if there is any juice (charge) coming out of it. that is a common problem with chargers, we trip over the cable or pull it out of the laptop by accident and it brakes little by little. if there is no charge coming out you can star by checking the jack you may have to cut it and have them check it again.
if you don't want to go trough the whole testing, just tell the TV repairman to fix it it should cost you about 30 bucks instead of 80 for a new original charger or find a chinese one on e-bay
if it works for you don't forget to rate me
Apr 28, 2010 | HP Pavilion dv7-1130us Notebook PC
My DC16 will start and then stop. I have to take
My DC16 also had charging problems. I called Dyson and they sent a new charger. The old charger only produced 23.6 volts DC, not the rated 28 volts DC. The new charger has a thicker round wire and produces 28.1 volts DC. Put a volt meter on your charger terminals and see if it is producing enough voltage to fully charge the battery, 28 volt DC. If not you need a new charger.
Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
PC suddenly lost power will not restart
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 05, 2009 | HP Compaq nx9010
I accidently connected a 28volt charger to my evo
if the battery charger powers the computer, then i would imagine the motherboard is fine...
there should be some kind of fuse insode the battery to prevent things like this from causing them to explode.
Replace the battery
Oct 11, 2009 | HP Compaq Evo Notebook N600c
I accidently washed my MP3 and it comes on and everything but it goes off cause the battery is low, but the thing is it won't charge!!! Is there anything I can do to make it charge or do I have to get a...
you mayhave to go and get a new one im afriad but you could try taking the battary out and letting it dry overnight and seeing again and let it fully dry first
Aug 30, 2009 | Sylvania SMPK 2066 Digital Media Player
Charge a DS lite without DS charger
turn your ds lite on, then realy quickly close the lid
Jul 20, 2009 | Nintendo DS Lite Console
Cameras Logo
Top Insignia Cameras Experts
Marvin
Marvin
Are you an Insignia Camera Expert? Answer questions, earn points and help others
