USB DRIVER - Computers & Internet
    Problem Solver:
  • 19 Answers
You might have to re-install your "Universal Serial Bus Controllers" here is how you do that:
1.Locate "Device Manager" usually by pressing start then typing "Device Manager" into your search menu if you are using windows 7. If not then it is easily found under Control Panel.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat step 2 until all item under "Universal Serial Bus Controllers" are uninstalled then restart you computer windows will re-install everything for you.
Posted on Mar 25, 2011
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Transcend v30 4G driver?
I think flash drive does not need any driver it is your usb driver try updating ur usb driver.
Dec 01, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb driver software needed for nokia 3500c model
http://www.nokia.co.in/link?cid=PLAIN_TEXT_406563 =)
May 23, 2009 | Cell Phones
USB Audio Device Drive Load Failure
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Dec 21, 2008 | Logitech V20 Computer Speakers
Nokia siemens ADSL Modem c2110 USB Driver
if u want Nokia siemens ADSL Modem c2110 USB Driver then reply me at binay00713@gmail.com the driver is working great in windows 7.
Nov 01, 2008 | Computers & Internet
How can i download usb driver form ADSL Modem c2110 i want to down load the siemens c2110 usb modem driver.Please help me.
Sep 29, 2008 | Computers & Internet
Got absolete 98se driver, need XP usb driver
Have you tried just plugging the device into your computer? XP doesn't need a third party driver for USB mass storage devices.
Dec 27, 2007 | Electronics - Others
USB driver
I want U S B driver for SIEMENS Modem C2110
Dec 16, 2007 | Interlink EPAD USB SGL PK-W/DRIVER ONLY...
Need Driver for USB Cable
You can obtain the driver from the music essentials kit cd....you may be able to obtain it from other resources however.....i would suggest a google search for verizon env vx9900 usb driver....also you will want this driver in place before plugging up your phone in order to avoid any other issues that might arise.
Dec 01, 2007 | LG enV VX9900 Cellular Phone
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
