Question about LG Washing Machines
I have a funny smell in the drum and it also makes my washing smell the same after it has done its program.
  • LG Master
  • 43,501 Answers
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Posted on Mar 25, 2011
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
Washing machine is showing pau13 and has a funny smell
Wrong category. You will get a faster response if you post the Make, Model of machine. Give as many details as you can. For example: "a funny smell comming from the motor, or a burnt electronic smell. I wold suggest reffering to the Machine's User manual, error codes/troubleshooting section. Or the Manufacturer's website, troubleshooting.
Dec 30, 2012 | Computers & Internet
Hi, The last two washes i've just done on my Hotpoint WD72, the washing has gone full cycle but has come out smelling damp. Any ideas? I've had it since 2005 when it was new.
This will potentially sound odd, but run the 90 degree cycle with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 26, 2011 | Hotpoint Ultima WD72 Front Load...
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
Inside smells like stale water
YOU NEED TO RUN A (CLEAN CYCLE) ON THE WASHER.THIS CAN BE DONE WITH A 1/2 CUP OF AUTOMATIC DISHWASHER SOAP AND HOT WASH CYCLE. YOU SHOULD BE ONLY USE 2 TABLESPOONS OF H.E. SOAP IF THE WASHER TO PREVENT THIS
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Apr 26, 2010 | GE WBVH6240F Front Load Washer
My washing machine is making a funny noise when it spins
well this is not very help full, funny noise's? hhmm? ok, cat stuck in the drum? no? lets try the bearings wearing out or braking up? broken spider? yes i did say spider, its the bit that holds the back of the drum to the driving shaft!! maybe you left a coin in a pocket and its found its way behind the drum, lets hope it dont find its way into the pump as well! broken suport springs? any number of other things????? but as for funny noise's,,, im stumped now,,oh, yes, just the one spring's to mind! my dog snores??? but he's no a very good washing machine!!!!!!!!!!!!!
Oct 20, 2009 | Washing Machines
Will not spin and smells funny
Does the washer agitate while in wash cycle? Does it move at all? It may be that the motor that drives the spin and wash cycle is not working. If it smells funny, it usually means that you have bearings gone bad or a belt, if it is belt drive, broken. You can replace these parts. All the parts involved with spinning can be replaced. The parts are available from the maker. It may be a spin clutch, agitator gear, pulley, or a transfer case..
Please leave good ratings, email me if you have more questions
Aug 07, 2009 | Washing Machines
Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Sep 27, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Drying cycle runs but does not dry clothes
more than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Nov 23, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
46 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
