Question about Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103
The clean light is blinking. Dishwasher won't start
  • 4,323 Answers
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Hope this helps... Please post back for further assistance.
Daniel
Posted on Mar 26, 2011
  • 188 Answers
SOURCE: blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 03, 2009
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
  • 188 Answers
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Posted on Apr 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Posted on Sep 10, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Clean light blinks on whirlpool dishwasher won't run
When the light flashes 7 times it means there is/was a problem with the hot water, including a bad heater element. Flip the breaker for a minute and hopefully that will clear the error; otherwise, here's a website that will take you through resetting it.
Apr 04, 2013 | Dishwashers
Clean light keeps blinking; dishwaher won't turn on
Hello Brian, welcome to FixYa.
Based on your post I understand your dishwasher is a Kenmore and the clean light is flashing and it won't start, correct ?
If so, this is usually an error code indicating there was a problem in the heating process the last cycle it ran, however if you could provide the complete model number I could speak specifically to whether it applies to your machine and potentially what to do about it.
Thank you for choosing FixYa and I look forward to your reply.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Jun 20, 2011 | Whirlpool Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
WHIRPOOL DISHWASHER CLEAN LIGHT SATYS BLINKING AND IT WON`T START WASH CYCLE
you have either a bad heater and or your water temp is too cold
toggle heated dry and high temp wash withing 8 seconds until all the lights light up
then hit cancel you should be able to use it now
Aug 24, 2010 | Whirlpool Dishwashers
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light blinks, dishwasher won't start,
turn the power off at the breaker for 10 minutes and check it then.
Jun 11, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
822 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
