Question about Belkin (F5D7231UK4) Wireless Router
I have a Belkin Router and instead of the Green Light it has an Orange Light and you cannot connect to it and just yesterday it was working fine i have done everythink to fix it,click to fix button,cutting it on and off,resetting/rebooting it!! PLease Help ME
I have a Belkin N600 HD (FD78301). It was working fine but after few weeks the light turned orange from green. I started having intermittent problems accessing the internet. The router has the...
Hi jaijeetc, There is no need to worry about a hardware problem. The orange light is just telling you that you didn't have an internet connection. So no, there is no need to worry about a hardware problem. Cheers, Alex
Jun 02, 2011 | Belkin Play N600 Wireless Dual Band Router...
Orange light on instead of green?
If this is on one of the local computer ports and it is blinking it is nothing to worry about according to the manual (http://cache-www.belkin.com/support/dl/p74559-b_f5d7230-4v7_man.pdf, page 11). It is just another normal status color like green but signifies a different network speed/duplex. If you are having issues with network connectivity, please reply with information such as:
1) Is the Modem light on and blinking? 2) are other machines using this router and able to get online? 3) did anything change to the computer plugged into the orange port such as windows updates or new hardware install?
Hope this helps some!
Mar 17, 2011 | Belkin (F5D7230-4) Router (587009)
My laptop is connected but can't get on the internet. The modem light on the router is blinking orange. The globe is not lit at all. It worked fine for about 4 months until yesterday. I have unplugged both...
go to my connection and check if the wireless was available or connected, if not availale, that means some files of the driver are corrupted. Run your recovery disk.
Nov 22, 2009 | Belkin F5D8236-4 Router
Wlan light orange
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
Apr 25, 2009 | Computers & Internet
Connection issues
Retain your password and user name if any, go into routers set up browser to find this. Press the reset button on back of unit with a pen tip. Go to your pc's and go into properties of your network cards and in the internet TCP/IP properties ensure obtain IP address automatically is selected. Go back into the routers settings (normally 192.168.2.1 in your web browser.) Make sure DHCP is enabled to automatically assign IP addresses. Type in any password and user name. Also check the cables as an orange light means either no connection or only 10 Mbps instead of the normal 100Mbps. If you still have trouble you may need to clear the DNS settings so go to Start then Run and type:- ipconfig /flushdns then press enter.(note the gap between ipconfig and the /).
Feb 20, 2007 | Belkin (F5D5231-4) Router
Belkin (F5D7231UK4) Wireless Router Logo
100 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
