Question about Mitsubishi WS-55805 55" Rear Projection Television
Green shadow on white objects Mitsubishi WS - 55857 The right edge of white objects have a green shadow that gets larger as the camera pans away. I've adjusted convergence and turned off the set, but it is constant. I would prefer to fix the problem myself, but would like direction, or help in finding a service manual.
    Problem Solver:
  • 5 Answers
Its been a long time since I did it, but I believe you can adjust the green convergence grid by using the service menu. I found instructions on doing this over on the avsforum message board (years ago) so you might want to search there.
Posted on Aug 14, 2008
We can set the convergences great but after about 10 to 15 minutes ithe reds lines start moving a little again will not stay in position. It's a widescreen Mitsubishi rear projection tv ws-55857.
The problem - you're setting the convergence settings, but you're not saving them, you're
simply exiting the menu screen. Be sure to save your convergence setting for each
of the three colors. It sounds like you're setting RED last, and not saving its convergence setting,
whereas the GREEN & BLUE are holding their convergence settings, since you're saving them
correctly before proceeding on to RED....
Mar 15, 2011 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 turn on/auto turn off problem
After it shuts off, you need to get a code from the tv by pressing the menu and device buttons together for 5 sec. A code will flash at you made up of 2 digits. Example. 2 flashes a pause and 2 flashes points to a convergence failure. If this is not your code post yours and I will help you.
Jul 06, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
After my tv warms up it goes to a red and green picture. like a shadowing of each other. Mitshubishi ws-55857 rear projection
you have a convergence problem
there are a set of ic,s that cause this trouble
if you call a servicer and depending on your area
cost should be 300 to 375.00
My co is in Tenn aea so basing that on our rates and they will vary in other areas of course
Oct 22, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
May 19, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 55 in connection problem
there is a setting in the menu under setup i believe it is called
"LABEL VIDEO INPUTS". check you owners manual. you need to make sure that
the DTV input is set to YPbPr NOT RGB.
Feb 22, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Nov 29, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
