Question about Dell Inspiron E1405 Notebook
Laptop turns on then I just have a bluish black screen?
    Genius:
  • 1,288 Answers
Probable video error. Likely caused by overheating due to build up of dust. The cpu gets the cooling from the fan 1st but the graphics chip gets it second and it is usually this that fails.
Try to blow out the vents with a can of compressed air, ( not a garage airline, which contains moisture), if that shifts a significant anount of dust and allows a boot up, you should strip the laptop and clean out the heatsink fan and radiator fins.
If not, issue likely to lie with the screen having failed, or the inverter failed
Posted on Mar 25, 2011
KDF-E50A10 - hard to see details during dark scenes and a dark bluish tint can be seen in background. When tv is turned off the screen goes black but has bluish tint toward the edges before it all goes...
Hate to tell you this but it sounds like your picture module is going bad. The bluish tint tells me it is leaking to the outside. Some problems with the LCD picture module can be fixed but I never had to fix one. Might check out some videos on repairing LCD picture tubes on YouTube.
Gillight
Dec 03, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Mitsi WS-65807 65" Played Wii for about two hours. Lost sound then picture. Now it wont turn on. Just get a warped bluish screen with lines. Any Suggestions?
Well i need more info. have you tried unplugging the tv for around 60 seconds? Was the "warped bluish screen" right before it died. Or is this when you turn it on it happens?(Bluish screen)? Because if no power at all and no picture at all. Could be Power supply. If you have some sort of picture with blue lines that are stable? You have a convergence problem. Get back to me with info i can help.
Dec 26, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Acer Aspire 7720-6569. The screen on the laptop periodically washes out to bluish-gray, then goes black with occasional horizontal streaks. Sometimes comes back to life. The external monitor works fine. Is...
Hi friend, In this case i would recommend you to please try and install the latest video drivers for the laptop and also try to move the screen of the laptop up and down to check if it makes any difference because it might be possible that the LCD cable is loose.
Dec 09, 2010 | Acer Aspire 7720-6569 Notebook
Screen went bluish white and won't power on or off
Mine goes white when I plug it into my computer to charge and then the laptop is closed or the computer hibernates. I simply slide the power switch up to the ON position all the way and hold it there for at least fifteen seconds before releasing it. It then turns off. I allow 5 seconds and it turns on as ususal, no problem. This might not be your problem, but worth a try...
Jun 21, 2010 | SanDisk Sansa e270 MP3 Player
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
Sep 18, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Bluish green screen on dell laptop
It might be that your red pin is bent out of shape. Please make sure ALL pins on BOTH ends are straight, and none are broken or missing. Also, make sure that they are firmly secure.
Jul 03, 2009 | Dell E176FP 17" LCD Monitor
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Dell Inspiron E1405 Notebook Logo
49 people viewed this question
Alun Cox
