Question about Brother DCP-7020 All-In-One Laser Printer
BROTHER ALL-IN-ONE COPIER 7020 PAPER TRAY
I HAVE A BROKEN PAPER TRAY GUIDE IN THE PAPER TRAY. WHERE DO I FIND A REPLACEMENT?
  • barbie122 Aug 20, 2008
    The back plastic paper size guide has snapped off. Can I get a replacement.
  • 3 Answers
SOURCE: Brother DCP-7020 Drum problems
Open the front of the printer by pulling on both tabs at the finger grips on both sides of the front panel. The front panel will flip down. The drum and toner cartridge comes out as a single unit. It is black plastic within gray plastic and has a handle like grip in the middle. Grasp this grip and pull the unit up and out. It feels kinda funny the first time you do it and you may feel like it will break, but it won't. Pull it up and out in a kinda circular arc. Do not touch the drum. If you ever need to replace the toner cartridge, press on the blue tap and separate the drum from the toner cartridge. You will have to replace the drum after every five toner cartridge replacements so practice doing it now. Note the tabs and slots on the sides before separating the drum and cartridge. Align the cartridge into the drum carriage and slide it in until it clicks. To replace the cartridge assembly into the printer, angle the cartridge at about 45 degrees and rotate in while pushing. It should click into place. If the front door then closes properly, you should have it in properly. Practice a few times and you should be an expert. For paper jams, there are many places to check and they may not all give warnings. First pull out the paper tray and check for and remove misfeeds. Remove the drum cartridge assembly and described here and check for and remove any paper. Open the back cover and check for and remove any paper. Open the automatic feed and check there as well as lifting the cover where the scanning surface is. Look in the rollers for the automatic feed for paper pieces. The last place almost never gives you a warning. Reach into the slot where the paper exits after being printed and grasp the whole top cover. Lift upward and it will open about 4 inches. This is a good place where small pieces of paper or even whole sheets may get stuck. Clean out any dust while you are there.
Posted on Oct 04, 2007
Soulvisitor
  • 1113 Answers
SOURCE: DCP 7020
If you are using non brother toner then that's the problem, if not it is the drum unit.
Posted on Dec 19, 2007
  • 12 Answers
SOURCE: Brother 7020 printer "fuser error"
The fuser has failed and needs to be replaced. If it is still under warranty Brother may cover it. If not you will have to take it to a Brother Authorized service center. It may be possible to find a used one on Ebay, even if its just for parts. Some of these smaller machines require extensive dissassembly to replace the fuser and shouldn't be attempted by a novice.
Posted on Mar 27, 2008
Ajkill
  • 2035 Answers
SOURCE: lexmark x4270 paper guide
You need to contact the Lexmark tech support, they the replacement parts:
http://support.lexmark.com/static/229-1-0-439.html
contact the chat support.............
Posted on May 23, 2008
checkitright
  • 1362 Answers
SOURCE: Brother MFC 8460 N, all
Make sure the stopper in the paper tray is snug against the paper. sounds like the paper is not properly in place and the tires are making the noise.
Could be it's trying to lift the tray and it can't, determine why; something stuck, out of place,
Posted on Jul 21, 2008
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Can the Brother DCP 7020 all in one printer print legal size paper?
Yes it can
  • Large paper capacity. Features a 250-sheet paper tray adjustable for letter or legal size paper. Plus, a single-sheet manual bypass for envelopes, labels or other types of media.
For your convenience Here is a link to the owners manual. Page 23 shows how to adjust the paper drawer to fit legal paper
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Jul 06, 2011 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Where is the fuser located on the brothers dcp 7020
Just below the slot where the paper exits into the catch tray. It may feel a little warm in the fuser area.
Thanks
Jan 06, 2011 | Brother DCP-7020 All-In-One Laser Printer
MACHINE STOPS, SAYING IT A PAPER JAM.
I would try taking some cleaner such as fantastic or formula 409, remove the paper trays and clean the feed rolls then open covers and clean any rollers in the paper path.
You can also use rubbing alcohol, but a soapy cleaner tends to do better.
Jul 21, 2010 | Brother DCP-7020 Black and White Copier
Paper Feed Tray will not feed paper. There is a
goes through below link and download the manual and try to clean the paper pick up roller and check i think it will solve your problem .......
Dec 14, 2009 | Brother DCP-7020 All-In-One Laser Printer
I have a Brother DCP 7020 copier. I have in my
I dont understand your problem but if you like this telefone numbre 1-888-800-7303 is a technical support of Brother.
Sep 29, 2009 | Brother IntelliFax-2820 Laser Fax
Printing slanted
Look at the paper tray and make sure the guides are aligned properly. Most of the time, there's nothing you can do except make sure the paper stack is arranged as evenly and as tightly as possible. I've found about a .05" variation in mine that leaves room for the paper to slant. So much for manufacturing tolerances..
Jul 01, 2008 | Brother DCP-7020 All-In-One Laser Printer
Laser printer does not print
Hi there it may just be that the paper tray springs are not pushing the paper higher enough not making contact with the paper detect sensor arm. Or the sensor arm is broken and will need replacing. Check the tray springs also check the sensor arm you will see it if you remove the cassette and look inside there will be a black plastic lever hanging down when you put paper in this lever should go up as the paper acts as a barrier thus telling the machine that there is paper in it.
Thanks J
Jan 28, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
