Question about Dishwashers
Hi Guru! I have got Ariston LFZ 3384 A IX/HA. When I run program dishwasher starts but in about 2 minute machine stop and on LCD blinding A-11 and start button also blinding. Connection with water from pipe is correct. Thanks for answer
  • 641 Answers
SOURCE: Ariston LS 620 A Dishwasher
Since, the pump doesn't stop working, it sound like a water level switch issue. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Posted on Aug 13, 2007
SOURCE: Dishwasher starts then stops
my kitchenaid dish washer clean light blinks 7 times then pauses. what is wrong?
Posted on Aug 30, 2007
  • 641 Answers
SOURCE: Ariston L63 Dishwaher problem
Unplug the power cable, remove the service panel and follow the next steps : - Remove one of the wires connected to the heating element and check with a multi-meter the element's resistance. In case you can't read any result,you should replace the element. - Check the water level switch- The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub.Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. - Control panel - look for loose wires. If you think that your main control PCB timer have failed, you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck !
Posted on Sep 13, 2007
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
  • 1462 Answers
SOURCE: doesn't shut off
i think you are hearing the drain pump going. take the bottom front panel off so as to expose the bottom tray. yoy willprobably find this full of water. mop water out and it should work. if fault reoccurs then you have a leak.
turn power off first
Posted on Sep 02, 2008
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
Hi my Ariston oven shows in the display error 07. I have an ariston oven FZ 87.1 (IX)
problem je v nedostatku vzduchu pri ventilatori,treba viac priestoru pre ruru
problem is the lack of air when fan, need more space for tube
Jun 29, 2011 | Ariston Technologies Ariston FO98P...
Hi, we have a Hoover HEDS668-80 dishwasher at work. The first problem we had was none of the programs would run this turned out to be a broken door lock. After replacement we managed to get one pre wash...
Hello... Did you check the water inlet pump is turning on to let water go inside the machine? I think if you starts a cycle and feels no water in machine it stops and give error... Hope that will be faulty or before that I'm pretty sure you forgot to open the water inlet valve because you recently repair ?? please check
Sep 21, 2017 | LG LDF6810 Built-in Dishwasher
Marking have worn off on front cover of ariston FM 22 M IX - oven
Try using ovenlettering.co.uk - I recently had same problem the symbols are easy to apply and look great. A brand new oven in minutes, speak to Mark - he can guide you through the process - very helpful
Mick Lawry
May 17, 2009 | Ariston Technologies Ariston FO98P...
Used some washing up liquid instead of dishwasher tablets, after i got rid of all the bubbles and drained it, it no longer starts. If i switch the power off and leave it for a few minutes i can select a...
dear sir vif you have used liquid soap in your dishwasher it will make mountains of bubles to kill all bubles outin a hurry take a sos pad put it in your machine and run the dishwaser this will remove all of the soao instantly try it it really works i am in the dishwasher bussiness and it does work thanks from gilles
Mar 15, 2009 | Ariston Technologies Dishwashers
Dishwaher not working
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
Mar 04, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
