Question about Honeywell Heating & Cooling
I have a bryant 395B and its not omitting any sparks from the pilot how can i fix this??
  • savon19111 Mar 26, 2011
    Is the exhaust blower located near the relief box cause if it is its not spinning. Also if I tap the spark ignition module do I tap it when the furnace is off or on?? Thank you!! Please rsvp.
    President:
  • 3,074 Answers
Before you get spark, the exhaust blower should come on. Does it? if not it maybe a bad relay in the unit. The black box is called a spark ignition module you may be able to tap on it, this may or may not work. Hope this helped Tim
Posted on Mar 25, 2011
Pilot stays on but nothing starts up after temp set Gas furnaceot Bryant. Pilot stays on strong
It sounds like the gas valve isn't opening to allow the burners to light . My bed a new gas valve .
Jan 02, 2015 | Heating & Cooling
I have a Bryant furnace model #340AAV036080ABSA and it's the auto ignite pilot, but pilot won't light. Gas is on to it, blower is working just no hot air so I figure pilot not lighting
Is the thermocouple burnt out.? A bad one of these will not allow the pilot to function . The thermocouple is the outfit that the pilot heats up when it tries to start up. A lot of the time this is the problem when the furnaces won't light up.
Nov 14, 2014 | Heating & Cooling
Bryant furnace
Check gas valve is not on pilot only check air filter is clean check connections to gas valve .
Oct 10, 2017 | Heating & Cooling
I HAVE A 20+ BRYANT BOILER THE PILOT LIGHT IS OFF HOW DO I TURN IT BACK ON PLEASE HELP THANKING YOU IN ADVANCE MS I
Turn the gas valve to pilot. Push knob down & hold. While holding, light pilot & keep knob held down for one minute. Let go of knob & see if pilot stays lit. then turn knob to on position. Boiler should then turn on.
Oct 18, 2010 | Bryant Heating & Cooling
36e93 bryant furnace inop
CHECK THE PRIMARY CONTROL TO SEE IF IT IS LOCKED OUT. IF THE RED BUTTON HAS POPPED UP THEN PRESS IT ONCE TO START, IF IT DOESN'T RUN THEN CALL A TECHNICIAN. ALSO CHECK THE SIDE OF THE MOTOR TO SEE IF IT HAS GONE ON THERMAL OVERLOAD(LITTLE RED BUTTON). RESET IT AND THEN PRESS PRIMARY CONTROL BUTTON. IF MOTOR BUTTON HAS POPPED OUT THEN REPLACE MOTOR. COULD ALSO BE A BREAKER. GOOD LUCK THANKS FOR AN HONEST RATING AND FOR USING FIX-YA.
Nov 09, 2008 | Bryant 462AJC021BA Air Conditioner
Bryant 36E93 gas package (pilot won't stay lit)
If your unit has a thermo-coupling this is most likely the issue This little sensor sends a milli-voltage to the gas valve telling it to keep sending gas for the pilot since its lit and all is good. They wear out and the gas valve thinks the flame has gone out (whick is hasnt) and kills the gas flow.
Jan 21, 2008 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
