Question about Hanako Games Fatal Hearts
Okay so I bought Fatal Hearts last year. Well I was about to show it to my friend. The game I had saved it on a flash drive. When I tried to set it up. An error message popped up which hadn't before. The last time I had it on my computer. The message said (move failed code 5 access is denied) ........... But it gave me the option to Abort/Retry/ or ignore. For it to keep going with the setup of the game. So I chose ignore, several times during the set up. Yet when it came to launching the game this message pop up.......( Create Process failed; code 5 ***** is denied) So tell me how can I fix this problem? We contacted the maker of the game. Who told us to uninstall the files saved on the flash and to try the Demo. thank you. We tried the demo which was able to run smoothly. So after that they sent us the full version files. For us to re-download them to play them this time. But when it came to setting up the full version. We weren't able to get the setup started. This pop up message keeps appearing. (The setup files are corrupted. Please obtian a new copy of the program) But no matter which game I download from the links you gave me this message keeps appearing. So what could it be this time? Also they suggested that it may be my computer or internet which is running normally. So could it be my anti spyware??? or will I have to buy a new version of the full game? please help
I recently bought a Kingdom Hearts 2 game and tryed to play it on my PS2 but everytime I put it in a disk drive it does this weird noise and then in a couple of minutes says that it cant read the disk. But...
What is probably happening is that the disk is either too scratched or too dirty to be read by the PS2's optical drive. Try cleaning the disk with a disc cleaning kit or by simply rubbing in with a microfiber cloth or 100% cotton shirt. If that fails to make it clean enough to be read, then you will have to get another, cleaner copy of Kingdom Hearts 2.
Mar 05, 2011 | Square Enix Kingdom Hearts II for...
Kindom Hearts II Freezing
Possibly the disk, you need to clean it with disk cleaner.
If the trouble still persist, it's the lens problem.
Open the case, then the mechanical case, after you see the lens, use a soft cotton buds, then put it in alcohol, then rub the lens firmly.
After that rub again with cotton buds without the alcohol, that should fix the problem.
Oct 23, 2009 | Square Enix Kingdom Hearts II for...
Memory card will not save
try to place the 64mb memory on the first slot...
some games only access first slot,...
Aug 08, 2009 | Datel Max Memory 64MB Memory Card
PSP only reads first 7 game saved
in psp get virus plz format ur psp than recover u psp than solve r problam thank u
Jun 03, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
My grandson was given a nintendo ds lite with 2 games i am trying to find game manuals for the games dragonball z supersonic warriors 2 and gameboy advance game kingdom of hearts chain of memories i went...
Im really bad at describing things but I hope this helps xD
Okay, Well you should go to a second hand shop and see if there is any manuels laying around. If not you should go to your nearest "Game" or "gamestation" Store
Your problem may also be that you are looking for "Kingdom hearts" not "Kingdom of Hearts"
Go with the first one Dear... least expensive
I hope I've helped xD
Apr 15, 2009 | Atari Video Game Consoles & Games
I put my game in but it wont show up
I've had this problem with a 60 gig also. first, does it read any games? If not you can try to clean the lens but that doesn't always work. if not I'm affraid you are S.O.L.. reason being, your ps3 can't read your disk so you disk drive unit is faulty. you can try to replace this yourself or send it to sony but they are going to charge you between 200-300 usd. the 60 gig is older so it is not covered by the mfg. 1 year warranty unless you bought a refurbed unit. in that case you should bring it back to the store from witch purchased it. Sorry... launch moddels are known for this in either 60g or the 20g.
Mar 27, 2009 | Video Game Consoles & Games
Cant save on kingdom hearts 2
yeah, the game format does not support the 64 mb card (Its weird like that) I had the same problem, until I went out and bought an 8 mb card. Hope I helped
Jan 03, 2009 | Square Enix Kingdom Hearts II for...
Saving game without running out of hearts
there is a way..
you have to press start+select+A+B
it should say return to game? and save and quit
i tried it for myself and it works.
Sep 16, 2008 | Nintendo Legend of Zelda: Link's Awakening
Video Game Consoles & Games Logo
Top Hanako Games Video Game Consoles & Games Experts
James Wishart
Are you a Hanako Games Video Game Console and Game Expert? Answer questions, earn points and help others
