Question about LG FLATRON M237WD-PM Monitor
Message Processing auto adjustment display on every minute. I want to stop auto adjustment. LG L1918S
nichu
  • 170 Answers
SOURCE: monitor message
hello this is nichu ,your monitor is not supporting your cpu .hence you are getting the message "processing auto config message from screen display".either you have to change your monitor or you have to change your cpu.next time while purchasing the pc get the help your hardware vendor to check out the compatibility
Posted on Nov 05, 2007
SOURCE: "Processing Auto Configuration" keeps showing up on my screen.
I have the same problem. I turn on the computer and get the message box "Processing Auto Configuration" blinking in the middle of my screen. I can keep using it or working on it, but it is very annoying. Whenever the message box pops up, the screen jiggles. I have tried to adjust the OSD but that doesn't seem to do anything and I cannot seem to use the Auto/Set button on the monitor or at least it doesn't seem to do anything. I have gone into troubleshooting the monitor, but get or find nothing there to help. I would appreciate a fix to this problem.
Posted on Mar 07, 2008
scottyfixit
  • 186 Answers
SOURCE: On My LCD monitor every time displays Auto Adjusting
It might say that when changing resolution or frequency in order to line the corners up with out cutting off. Might also be video card sending it mix signals too.
Posted on Apr 23, 2008
MUKHTAR
  • 2022 Answers
SOURCE: Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Posted on Dec 02, 2009
lyonzy1
  • 208 Answers
SOURCE: Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
Posted on May 20, 2010
I am getting Processing auto image adjustment popup continuously. Help me how to stop it.
You'll probably have to turn an auto-adjust option off within the monitor settings.
Feb 18, 2018 | Computers & Internet
Auto processing
The auto processing is the monitor trying to adjust to a particular resolution. To help you control display quality, please follow the steps given below:
-Open the 'Display Quality troubleshooter' by clicking the Start button, and then clicking 'Control Panel'.
-In the search box, type 'troubleshooter', and then click 'Troubleshooting'.
-In the left pane, click 'View all', and then click 'Display Quality'.
GuruAid.com
Mar 20, 2016 | Lenovo ThinkCentre Computers & Internet
Processing auto image adjust appeares more times
open the rear cover there is a trimmer, with a screw drive adjust it by turning right or left; the message will not appears again
Oct 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Pl. solve my problem "PROCESSING AUTO IMAGE ADJUSTMENT" message display continusly
I've tried all ideas by removing this ,,processing auto image adjustment'", but all of them was not working. So, i found truly and simple solution: The problem is made of constant autoself incorrect working button ,,Auto/set". This button is near ,Turn off/on monitor". Eventually you need to turn off this button, but there is no solution to do it, but i found one - i used hair clipper to press this button PERMANENTLY. And it WORKED, and also no screen buttons are working
Oct 02, 2010 | LG Flatron L1515S 15" LCD Monitor
May 18, 2010 | LG Flatron L1919S LCD Monitor
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Fluctuating display when processing data in my PC
Does it mean that text, or any data found in your monitor has a shadow? There is nothing wrong which kind of system your using (xp, linux) it is on the monitor. It is on the mixing of color, the repair man/technician knows how to adjust those things.
Thanks
Nov 19, 2008 | LG Studioworks 700S 17" CRT Monitor
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor message
Nov 04, 2007 | Gateway FPD1530 15" TFT LCD Flat Panel...
LG FLATRON M237WD-PM Monitor Logo
375 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
