Question about Philips Computers & Internet
Screen went black and a window came accross the screen saying attention entering sleep mode......and then it said no video input...
  • Philips Master
  • 6,771 Answers
It sounds like the problem is in your computer, hook a spare monitor to verify, if you have the same problem, it is your tower that needs to be checked out.
Posted on Mar 25, 2011
On the screen is only /attention / entering sleeping mode/no video input what is a problem?
1.This means that your comp is supplying power to the comp...
2.check video cable...unplugg and replugg...
3.Still not resolved...unplugg all the devices from the back including the power cable...
4.then press and hold the power button for 20 sec...then connect the power cable keyboard mouse and the monitor cable...
5.then try to start the comp...
6.still not fixed...switch the voltage selector at the back...
7.still not fixed need to reset the ATX cable inside the comp...
8.Still not fixed can be a hardware problem...
Apr 06, 2011 | Computers & Internet
I have a blank screen on my HPf1905 monitor. I have a HPm7330n computer. How do I know if its the monitor or the video card? Monitor shows a message no input signal,then goes to sleep mode.
if the message you recieve is no input signal if only means that you have a problem with your video card, the monitor is fine but you need to have your video card check
Nov 21, 2009 | Computers & Internet
My problem is the same, it happens when i'm in fullscreen.
go in and fix the power settings under screen saver disable sleep mode on drives and monitor disable sleep mode on every thing just use blank screen instead
bes fix 4 ya
Jul 29, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Screen
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Jan 19, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Can u help me?
this is system power scheme, to save power when the machine doesn't detect any action on the keyboard of the mouse for a preset time frame.
go to control panel>power options and change the hard drive shunt down time, and the monitor shunt down time to what ever you like.
Oct 23, 2008 | Philips 190B6CB/27 19" LCD
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
Computers & Internet Logo
168 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
