Question about GE GFDN110GLWW Dryer
How do I get inside a GE GFDN110GLWW so I can install the LP gas conversion kit?
  • Bill Kuhn Mar 25, 2011
    my e-mail addy is tehuti12@gmail.com. I got the dryer apart and the lp kit in, but I would love to have the service manual.
    Thanks,
    Bill Kuhn
  • GE Master
  • 2,605 Answers
Welcome to FixYa.
I can help you in which-ever manner you decide.
1) I can send you the entire service manual via email...that will obviously require you to post an email address.
2) you can download the service manual from my windows live account at macmarkus@live.ca however you'll need to confirm via emailing me there that you want to do it in that manner so I can allow you to
3) I can lay out the tear-down procedure on here to guide you through it...this being the most time consuming, but it's up to you.
Let me know if any of these options interest you and I'll help in whatever manner I can. I'll look forward to your reply.
Thank you for choosing FixYa today.
Regards,
Macmarkus :)
Posted on Mar 25, 2011
  • Mark MacDonald
    Mark MacDonald Mar 25, 2011
    Hey Bill,
    I'll fire it off to you right away. It will be less than 3MB so you shouldn't have a problem depending on you email account settings.
    Some programs will send email with attachments directly to "junk" box so look there if you don't get it soon.
    Regards,
    Macmarkus :)
How do I get inside a GE GFDN110glww so i can install the LP gas conversion kit?
Hello MacMarkus i need the same can you help me please!! this is my email, vichba@msn.com
Dec 19, 2011 | GE GFDN110GLWW Dryer
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
I have a 48" GE Monogram 4 burner with griddle gas/ duel fuel range (ZDP48N4GD1SS) that was set up for natural gas. I need to convert it to LP but the parts website doesn't show a conversion kit for this...
I just bought a new/used GE mongram natural gas range and need an LP conversion kit. Called GE and found them very UNhelpful. Can this be this hard? The party I called will not take the range back. $3000! I thought I got a great deal and cannot use the range the way it is. I need help too.
Aug 19, 2010 | GE Monogram ZDP48N4GHSS Stainless Steel...
I need a conversion kit for a GE ZGU385LSMSS gas cooktop to change from lp to natural gas.
Please follow the below link to purchase your conversion kit -
http://www.homeeverything.com/web/sitefiles/product.asp?sku=11995&ref=cNexTag
Good Luck!!
Thanks
Oct 14, 2009 | GE 30 in. JGP336 Gas Cooktop
Changing from natural gas to lp.
By getting a gas license! LOL
Remember to tip your waitress! I'll be here all week - Goodnight!
Alright...got it out of my system...here we go:
1. Find out if a conversion kit exists. Answer: Yes it does...in fact it came with it originally. If it had me doing the install, I would have taped the kit to the back of the range.
http://www.fixya.com/support/p106248-kitchenaid_kgsa906pss_gas_kitchen_range/manual-13680/page-7
....and I quote, "IMPORTANT: Your cooktop is factory-set for use with natural gas. If you wish to use L.P. Gas, an L.P. Gas Conversion Kit is included with your new range. Models with the TripleTier Flame Burner will include a TripleTier L.P. Gas Conversion Kit and a kit for standard ranges. See “Installation Instructions” for details on making this conversion.
2. Obtain the kit. This is more difficult than actually doing the conversion. Unless you have a dealer nearby, I'd simply call Kitchenaid directly: (1.800.461.5681) They will either send it to you directly (quite possibly for FREE) or point you in the right direction.
3. The kit will come with instructions, but briefly, here's what you're getting into: The kit will consist of 1-3 orifices. These will reduce the amount of flow going to the burner(s).
Why? Two reasons: a) Propane burns hotter and b) Propane moves quicker than N.G.
You might need: Allan Keys, Screwdrivers, Channel Locks, Adjustable Wrench.
You'll just disassemble the manifold, install the orifice(s), and GO!
Good Luck.
Sep 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
How do i get to gas valve to install lp gas conversion kit on a ge dryer model drsr495gg7ww
call your lp provider as they often will send out a tech to do this conversion for free. after all you will be buying the gas from them.
Aug 17, 2009 | Dryers
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Conversion from natural gas to LP
there was no direction with the parts
Sep 14, 2008 | GE Profile DPSB620GCWW Gas Dryer
GE GFDN110GLWW Dryer Logo
96 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
