Question about Nintendo Wii Console
My wii remote cant turn on the power - Nintendo Wii Console
    Problem Solver:
  • 6 Answers
1. Make sure your Wii Remote syncs with the Wii upon pressing a button on startup. If it takes a while, you may want to get a new Wii Remote, or just press the button on the Wii. Oh, and, make sure the battery is on.
2. Can you actually use your Wii Remote? If you can't, you'll want to see above.
If you can,
3. I hear hacks can alter things, so make sure you don't have hacks, whether you put them on or someone planted them on you.
4. Lastly, make sure that the Wii Remote is facing towards the Wii or the Sensor Bar, as it doesn't do the backwards or far-away thing that PS3 and Xbox controllers can.
If those don't work, I recommend replacing it.
Or just pressing the Power button on the Wii.
Posted on Mar 26, 2011
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
Cant get pass the "press A button" screen
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Sep 05, 2008 | Nintendo Wii Console
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
I cant get my wii remotes to sync after i replaced the batteries
Try this: 1-turn on the wii from the FRONT power button 2-hold the SYNC button under the SD cover (on the wi, not the remote) for 5 seconds 3-Attempt to SYNC the wii remotes again
If that fails: 1-Replace the wii remote batteries 2-Repeat above steps
if this still doesn't work, reply to this, and I will help you more
Jan 25, 2011 | Nintendo Wii Console
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
I can turn my wii unit on with the remote, but cant turn it off with the remote. also I get nothing on the tv screen when I turn it on. we just got the unit today and I know nothing about it
Try switching the cables connected to the TV to your Wii, plug those 3 pronged cords into a different side. And about the remote thing, Im not 100% sure but i think you might have to open the battery compartment and press the red button to sync with the Wii.
Jan 10, 2010 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
Wii remotes cant get synchronized
Press the red button near the SD card slot then press the red button undre the Wii remote's battery cover to synchronize again.
Feb 28, 2009 | Nintendo Wii Console
Reconnecting
When you turned off the Wii, did the light turn red or amber?
If you haven't done this already, hold the power button until it shuts off, and the light is red. Power it back up and try your remote again.
Jan 25, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
56 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
