Question about ViewSonic VX2235wm LCD Monitor
Just started flicker today, I've had this monitor for at least 2yrs and no issues ever. VX2235wm and used ALL the time.
  • dcorlew238 Mar 27, 2011
    Thanks! I really appreciate your advice and expertise. I found the service manual for my monitor online and pinpoint what I think are two 1000uf caps. They look ok, but will probably proceed to replace them to see it this fixes the "flicker" issue. Thanks again.
  • 6,771 Answers
The problem is in the power supply / inverter board, commonly caused by bulging capacitors at the top, "indicating they are open" the capacitors will need to be replaced to correct the issue.
Posted on Mar 25, 2011
  • 5 more comments
  • dcorlew238 Mar 26, 2011
    good info. Based on your advice about the bulging capacitors, I checked and there are repair kits for this model. While at it I opened up the unit and took a peek at the board. I can't say for sure any are actually bulging. Hmmm. Maybe I should wait to see if the flcker worsens.
    Or should I just go ahead and replace them all? What do you think is there anything else that may be the cause?
  • John Cunningham Mar 26, 2011
    I recommend you replace them and check for bad solder joints because more damage may result if not serviced in a reasonable amount of time, the caps that bulge will have a slight cone shape on top compared to nice a flat top. The common values you are looking for will be 820uf and up that cause the most problems, so for example your monitor may have 1000uf capacitors in the power supply section.
  • John Cunningham Mar 27, 2011
    Glad I could help!
  • dcorlew238 Mar 30, 2011
    I have an update. I had quit using the monitor because the flicker issue became>> I would power on and it would shutdown after a few seconds, so I set it aside until received the cap kit. Just replaced all the caps there were several. Still getting the same "newer" issue of it turning off after a few seconds. The display will work and is readable and then goes blank.
    Any advice or troubleshooting ideas to pinpoint the problem?
    Thx, Dave
  • John Cunningham Mar 31, 2011
    The cap kit will fix 90% of the problems in the monitor, if you have a meter check the regulator transistor for shorts or open and check the secondary parts in the power supply/ inverter board, it is possible the inverter transformers that power the back lights may be the issue, there are two of them "look like a black box" resolder the transformers. The other problem that concerns me is the back lights "may be faulty" two things I need to know! when monitor shutsdown does the power light stay on? second! does it still flicker before it shutting down? thanks John.
  • dcorlew238 Mar 31, 2011
    Ordered a new monitor today! : (
Viewsonic vx2235vm does not turn on
This really sounds like you have a power supply board that is having problems with the filter capacitors which are causing it to not start up correctly. Here is a like to a repair guide including video instructions showing how to open and repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Part one of the video guide:
Feb 07, 2013 | ViewSonic VX2235wm LCD Monitor
Our viewsonic monitor is VX2235WM-3 the
The short answer is no, becuase by time you pay the $50 for the backlight, and $75/hour for the tech to fix it, you can buy another 22inch for the same price and have a 5 year warrinty.
Sorry,
Have a nice day
Aug 29, 2011 | ViewSonic VX2235WM Monitor
I just have a question - - - I've just unpacked my Viewsonic 22" monitor and noted there are two data connection cables. One is the standard delta connector, and the other is a rectangler, I...
Hello and welcome to FixYa!
I'll recommend you to read the User Manual thoroughly before using the product, this will unlock all the features/precautions and other data which you may not be aware of, at this time.
I hope you will understand my point.
Download the Printable manual from here.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
May 07, 2011 | ViewSonic VX2235wm LCD Monitor
How to open a viewsonic vx2235wm monitor?
Here is a link to a repair guide with pictures and videos showing how to open the unit and then repair the power supply board that is the most common cause of issues in the VX2235wm monitor.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2010 | ViewSonic VX2235wm LCD Monitor
Monitor flickers on and off
power supply is more than likely going to need some new capictors. if you can solder its not a hard fix. just look at the power supply and look for swollen caps.
Jul 06, 2010 | ViewSonic VX2235WM Monitor
View Sonic Monitor
This model has a know issue with the power supply. Check out our repair guide at: www.ccl-la.com click the monitor repair link and then go to page 2, its listed under the Wetinghouse LCM-22W3 monitor, they use the same power supply - DAC-19M009. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 28, 2009 | ViewSonic VX2235WM Monitor
My viewsonic vx2235 has a blue light on but no picture at all. Can i still use this monitor? I really dont want to buy another one so i am hope that i can just replace a part cheaply. Theres power but no...
Assuming your cable is good & your PC (video card) is properly functioning & everything is plugged in correctly,;
If the screen flickers a bit when you start it, then the problem may be in the power circuits. Open the back & look for burned components on the circuit board. (capacitors, fuses, resistors, transistors, whatever.)
If it does not flicker then the bulb is likely burned out.
ALSO: you should read this guy's experience. ----> http://www.avsforum.com/avs-vb/showthread.php?t=1136249
Sep 05, 2009 | ViewSonic VX2235wm LCD Monitor
Vx2235wm lcd flickers a bit then turns white
White screen is an indication of a faulty video board.
A blown fuse in the actual screen will cause the same effect but usually these do not reset on a fresh startup.
You can check the ribbon going from the video board to the back of the screen to see if it is somehow working loose, but I think based on your description that this isn't the problem.
ebaysbammbammfran
Oct 07, 2008 | ViewSonic VX2235wm LCD Monitor
Viewsonic vx2235wm display issues
There are many areas of the LCD monitor that can cause very much the same effect that you see. Most of the time there are capacitors that go defective.
The caps can be tested with an ESR meter. This is a time consuming job. The caps are mostly surface mount types, and will require the proper tools to change them.
Normaly the service centers will change the defective boards rather than try to service them. There is no component level service support for any of these monitors.
In the end, it would be cheaper for you to replace the monitor rather than to fix it.
Jerry G.
Jun 02, 2008 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
268 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
