Question about Schwinn Stingray Yellow Finger Groove Grips Bicycle Bike
How do i get the hand grips off my schwinn stingray?
    Problem Solver:
  • 12 Answers
Please refer to the video below: How to Remove Bike Handlebar Grips
-The process of removing the hand grip on this video is the exact procedure how you can remove the grips from your bike
Posted on Mar 26, 2011
I have an old Stingray, serial number SNHUAO4K45049. i,m located in Australia. I,m just trying to obtain as much info as possible regarding this bike. Cheers and thanks in advance. Chris Hogg
Rather than do the work for you I'll point you to the resources. Just Google Schwinn stingray serial number. For other stingray info just search for Schwinn stingray.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Oct 27, 2016 | Cycling
I have schwinn stingray bike but the frame serial number doesn't appear to be a schwinn number. would JAK 13245 be a schwinn serial number
It doesn't appear to be a Schwinn frame. I suggest that someone has switched out a phoney frame, added Schwinn parts and sold it as a genuine Schwinn. Schwinn date codes are available on-line.
Oct 12, 2014 | Cycling
How do you separate the crank halves on a Schwinn stingray
A typical Schwinn Stingray comes with one-piece cranks. This means the cranks are continuous from one pedal to the other. Here is a tutorial on removing them from Park Tool Co.:
Park Tool Co ParkTool Blog One Piece Bottom Bracket Service
Apr 04, 2014 | Cycling
I need a seat for a Chopper Sting Ray Schwinn bike
What color?
Check eBay (about 100 of them)?
search "schwinn stingray seat"
Apr 24, 2011 | Schwinn Stingray Chopper Youth Bicycle...
I cant get the stingray bike seat tube out of the frame.......... heeeeeeeeeeeeelllllllllpppppppppppppppppp mmmmmmmmeeeeeeeeeee
Don't get your hopes up too much because it is seized up. You can try some rust remover around the outer seat post and let it sit for a few days, keep pouring more each day. After that try vise grips and a bench vise. Patience is a virtue, but sometimes that doesn't even work. Had to junk many a old classic for the same reason. Good luck.
Jun 19, 2010 | Schwinn Stingray Chopper Youth Bicycle...
Schwinn Stingray Chopper master link on chain
look for adifferent looking link more oval than the rest it is also possible that there is no master link that the chain was joined with a chain tool especailly if is a multi speed bike with a derailleur
Nov 14, 2009 | Schwinn Stingray Chopper Youth Bicycle...
How do i adjust the brakes on a schwinn stingray low rider bicycle? the front brakes dont grip the wheel enough to stop and the rear is rubbing on one side. thanks
Let us start with the rear. The brake arms will have a small screw located on them near the pivot. You can screw these in to adjust the relation of the pad to the rim. You can also (if that didn't take care of it) remove the brake arm and move the spring's pin to the next hole to make sure it properly clears itself.
The front can be tightened on the brake levers with the adjustment barrel, or, if that is already fully turned out, turn it all the way back in and release the cable at the brake itself and retighten it when you have adequately adjusted the brake there.
Check out Parktool.com's repair help page (located at the top right hand of their homepage) for excellent detailed and illustrated help in bike maintenance.
Hope this helps a little,
matt
Sep 19, 2009 | Schwinn Stingray Chopper Youth Bicycle...
Schwinn stingray too small.
check local bike shops and or have one made for you depending on how much you wish too spend
May 10, 2009 | Schwinn Stingray Chopper Youth Bicycle...
Replacing occ stingray front end
As long as the neck of the fork that goes into the frame is the same length and width (or circumferance) it should fit.
Feb 13, 2009 | Cycling
Schwinn Stingray Yellow Finger Groove Grips Bicycle Bike Logo
456 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
