Question about Ovens
Frigidaire ovens PLCF489CC Electronic Pilotless Ignition
PILOT IGNITION WONT TURN OFF, IT KEEPS CLICKING
  • Ovens Master
  • 5,568 Answers
And it will eventually die from that since they are not designed to withstand prolonged operation.
Pull the knobs off to see if the cam operated switches can be seen.
If so, then operate them with an insulated stick (skewer, for example) to see which one is not opening as it should.
Ranges are by their nature grease and dust collectors in places you can't reach well.
If you don't have time to mess with it now, pull the plug to avoid killing the ignition transformer.
Posted on Aug 03, 2008
The main oven ignition keeps clicking away after the oven has been on a few minutes. It will click away for ages before gradually slowing down and stopping.
Your stove has a faulty sensor that is used to detect the flame of either the pilot that gets lit by the ignition or the burner itself. Without knowing the brand and model of the oven, it will be impossible to know which parts are affected.
Dec 03, 2014 | Ovens
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Gas mark nob not having any effect on gas levels in the oven seems like it is on its highest setting all the time? Also the ignition keeps clicking away all the time could this be a s/c on the wire from...
    Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
    Dec 23, 2009 | New World G60m Gas Single Oven
    I have a gas oven ~ not sure of the age. I
    clean around your pilot light, there may be gunk built up around it.
    Sep 27, 2009 | Kenmore Ovens
    I just cleaned by hand by magic chef wall oven and now I can't
    Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
    Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Pilot light
    It was an electric ignition
    Thank you
    Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
    Pilot Light - Frigidaire Model FGF326ASF
    Hello jaronwayne
    Welcome,
    That range does have sealed burners.
    Are you sure it has a pilot light and not Electronic ignition?
    Where I live , if we call public service they will come out for free and light it for you!
    I'm checking that model and I'll get back to you!
    Huuum
    Oct 16, 2008 | Frigidaire FGB24S5A Gas Single Oven
    Ovens Logo
    227 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
