I need to use my laptop for my job as a karaoke presenter but i cant get the picture on my tv even though i have all the relevant cables in place
  • 98 Answers
Make sure your tv or monitor is on the right imput. usually if its a S-video or red, white and yellow wires it should be imput number 3
or click Fn and F5 at the same time on your computer
hope this helps plz rate thx
Posted on Mar 25, 2011
I connected mediacom karaoke MCI 6200TW premium to LG tv. Start up sound heard but no video came out.
It would depend on the cord that plugs into the tv. If you have the red, yellow, and white that plugs in then the video cable needs to be plugged in. You need to plug in the video cord. It sounds like you only have the audio cable plugged in. Try a hdmi if there is a outlet for it.
Jul 15, 2016 | LG Televison & Video
I need a operator manual for a lonestar sk-104 karaoke manchine
I have the same one. and I have had another model also.they are almost the same.If I am correct it is a cassette karaoke player.They take a special cassette that says lonestar super K.these players and tapes were from the 1992-1994.when you hook to the tv, the tv needs to be on channel 3 or 4.the back of the machine should have a switch with 3 &4.make sure both are on the same.on newer tv you may have to figure out the input & output.some say video some say line 1 line 2 etc.my machine uses a cable cord from tv to machine.any tape will play in them ,but only the special ones will put words on the tv. if you use the special tape when you put it in the machine only one side plays.it tells you on the tape.also only one side of the duel cassette compartment will put words on screen.my sk104 is side B.Hope this helps.if you still cant get on screen words,it could be that part of the machine just doesn't work anymore.that is what happened to my other one.
Dec 15, 2012 | Music
The screen on my big screen is black it still works i can hear the tv but just cant see the pictures
If all the following apply to your set:
(1) Adjusting the brightness and seeing that video is present (just black)
(2) The TV's menu system is visible on screen even though no images are
(3) Your particular SHARP model supports picture in picture mode
Then I suspect that the problem is your TV's picture-in-picture sub-board. All external video sources & the internal tuners must pass through this board before being processed and displayed on the picture tube (even when PIP is not enabled). As far as I am aware SHARP does not provide this board as a spare part anymore, but they can be repaired at the component level if the failed component is a generally available device.
Regards
Jun 27, 2010 | Sharp 32C-240 32" TV
When I connect my model KW-SA235 to my PC and TV, I get "no signal" on the TV. What am I doing wrong? I'm trying to run a PowerPoint presentation from a CD on my laptop.
PC to TV KW-SA235
Even though I have a hi res. 40 inch TV from Sony the quality of the picture from the PC to TV is far inferior to the small screen on my laptop. I can read all the shortcuts in the laptop, but they are completly unreadable on the TV.
I have tried to use the adjustment for increasing the sharpness, but it hardly changes. I tried to use the AV cable instead of the RCA one and although the definition was the same it went black and white,
The instructions tell me to change the computer resolution and refresh rate the pictures are so small that even after scanning then at 600 bpi I cannot see what is on the pictures of the screen.
This is far below the quality that I was hoping for and I am really disappointed. Even copying old videos from the 50's I am getting better pictures than this. There must be a better way of getting the very good screen results on my laptop, - an almost brand new Toshiba , onto my almost brand new Sony DVD Recorder. HDI to the Telly works fine but there does not seem to be a HDMI input, on the DVD recorder only an output.
The inputs available are RCA, AV which the laptop does not have, a scart and a USB which I do not seem to be able to use. So how do others do this. I have a lot of things on a 1.5 terabyte hard disk that I want to put on DVD.
Any comments would be welcome. Thanks George.
Nov 29, 2009 | KWorld PC to TV (0872880887527) Video...
Cant get the cable picture dont know what happened to the cable behind the tv but no picture or sound is present.
Check the F-connector. Unscrew cable from set make sure F-connector has not slid forward on cable and that copper center wire extends out.
Jul 08, 2009 | Sony KV-35V36 35" TV
S Video cable
you need to toggle the display on your laptop. be sure that when you connect the tv or external monitor the laptop should be turned off. to toggle the display kindly press Fn followed by F8. for old tv's you need to have an S-video cable. for LCD monitors, either VGA or DVI cable will help.
i hope this info helps you.
Sep 09, 2008 | Dell Inspiron 6000 Notebook
How do I Record?
well, seems like your vcr is attached to your tv by the antenna cable which you need to program to get it to record. but he is an easy way to record and you will get a perfect sound and picture. Well, you need an RCA cables. you either have rca cables or scart plug. either on will do the job. you need to take the audio and picture cable OUT source of your channels IN to the vcr. now, OUT of the vcr IN to your tv. on the vcr you should change the channel to either AV or LINE..then you will get sound and picture. let me know how it goes
Jan 15, 2007 | Panasonic PV-8451 VCR
Sony 60" HDTV Plasma WEGA....Picture Problem
Sounds like your component cables may have come off its contact point. Check to see if your cables have become loose. Pushing them back in place should take care of that but check at the source output and the TV's input. Red Green Blue, when ever one of these 3 come out of contact the TV will produce a color hue relevant to what color remains in contact, looking faint and discolored. If you do find a loose cable connection, inspect the contact ends and squeeze lightly to restore a snug fit but don't do it to hard or you may damage the prongs.
Oct 22, 2006 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
