Question about Solar Fan Impressions 3 Speed/4 Wire Ceiling Fan Switch
I have a 3 speed fan switch with 4 wires. The wire colors are grey,black,yellow,and brown. Where do they go such as L,1,2,3 on the switch?
    Novelist:
  • 157 Answers
Hello. Not realy familiar with those four in combination, but here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope these help clear up you issue.
Posted on Mar 25, 2011
  • 710 Answers
Did you get a wiring diagram with the switch/fan? This should tell you which is which.
Each manufacturer has different color coding. If you didn't get a diagram, contact the manufacturer for instructions.
Good luck,
Handie Andie
2 Suggested Answers
  • 5245 Answers
SOURCE: replacing 3 speed 4 wire
Copy following link for 3-speed fan wiring:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 30, 2012
Broken 3-speed ceiling fan switch
Observe and read manual carefully
Jul 23, 2016 | Dryers
Hunter ceiling fan, replacing speed switch, what wire goes to the L, 1, 2, and 3?
I can only guess since I don't know what model or what color wires you have. Here's wiring for single stack switch on some Hunters;
L- black
1 - grey
2 - brown
3 - green
Hope this helps.
Feb 06, 2016 | Hunter Ceiling Fan Control Switch
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
I have a 3 speed fan switch that i am replacing, b...
Hello. I really hope the 2nd grey is simply a faded purple or green. The most common configurations would be: L - Black, 1 - Grey, 2 - Brown, 3 - Purple or green. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope these help clear up that nasty faded color for you, and don
May 21, 2010 | Speed Ceiling Fan 3-speed Switch By...
THE WIRING ON THE FAN CLUTCH GOT CUT AND THE WIRES FROM THE TRUCK ARE YL/RD,BLK/RD,GREEN/GRAY,RD/GREY,GREEN THE WIRES FROM THE CLUTCH ARE RD,GREEN,WHITE,ORANGE,BLACK. TRYING TO BE SURE BEFORE I CONNECT...
1) ECM Fan Clutch 1) K160 18BR/OR Park Lockout Solenoid Control Green
1) BR / OR = Brown/Orange unit with Green
2) K900 18DB/DG Sensor Ground 2) Black
2) DB / DG = Dark Blue/Grak Green unit with Black
3) K161 18BR/LB Fan Speed Sensor White
3) BR / LB = Brown/Light Blue unit with White
4) Not Used
4) Not Used
5) F856 18YL/PK 5 Volt Supply Orange
5) YL/PK = Yellow/Pink unit with Orange
6) F504 20GY/PK Fused Ig. Sw. Output Red
6) GY/PK = Gray/Pink unit with Red
With this, you have 5 due color cables unit to the 5 full color cables. Run.
Good luck, and rated this help (and us chat).
Aug 27, 2009 | 2004 Dodge Ram 3500 Truck
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Solar Fan Impressions 3 Speed/4 Wire Ceiling Fan Switch Logo
2,525 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
