Question about Kenmore Washing Machines
My washer is a one speed automatic top loader. It agitates really well but then when the knob turns to drain, it just sits there. i have checked the exhaust hose and it works. I bought this washer in March of 1997
    Problem Solver:
  • 3 Answers
Hello all you have to do is ajust the rubber feet make sure the machine is level you could allways use a spirit level to be sure
Posted on Mar 25, 2011
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I have speed queen commerical washer top loader, last night it stopped agitating. What could be the problem?
  • Make sure lid is closed.
  • Pull timer knob out to start washer.
  • Make sure power cord is plugged all the way into the electrical outlet.
  • Check the house fuse or circuit breaker.
  • The motor overload protector may have stopped the cycle. It will reset itself in two or three minutes and restart the washer automatically.
  • Broken drive belt. Call the service person.
  • These are a few possiblities and steps to take for further analysis
  • Nov 28, 2010 | Washing Machines
    Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
    Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
    Sep 01, 2009 | Kenmore Washing Machines
    Kenmore washer quit working
    it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
    Mar 16, 2009 | Washing Machines
    GE WJSR1070A top loader wont aggitate.
    You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
    Mar 05, 2009 | GE WJSR1070A Top Load Washer
    Washer won't drain or spin
    top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
    Mar 02, 2009 | Kenmore Washing Machines
    Machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore elite won't agitate properly
    Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
    Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
    Kemore elite top loader won't fully agitate
    If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
    No spinning or agitating
    If it has a mechanical timer switch, (the main control knob) that is possibly the culprit. The timer switch is basically the "brain" of this type of washer. I had this problem on a washer.
    Dec 26, 2008 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    16 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
