Question about Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
The Epson Stylus Photo R200 and R320 Status monitor programs are not available in Vista. Epson does not offer a solution that I know of. Do you have any information on how to monitor the ink levels with these printers?
Thanks for your help. Jack Spence
I need an Epson Stylus Photo R200 Status monitor for Vista
  • 3 more comments
  • Anonymous Dec 01, 2008
    non riesco a visualizzare lo stato delle cartucce d'inchiostro
  • lpautobotql Feb 01, 2009
    is there any way to just download a status monitor for vista for r200 and r300 series?
  • Anonymous Feb 06, 2009
    Hi, Does anyone know how to monitor the ink level, the status monitor wont work, i`m using vista home basic. Thanks
  • Anonymous Mar 25, 2014
    turn of low ink light
    won't recognize ink
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Posted on Apr 19, 2009
  • sunshineme Jan 04, 2014
    Tried this and thank you it now works
Hi - I have the R320, I downloaded the following driver epson11889_easyprint_310a from epson site. I uninstalled previous driver which was for the r200, installed this one and everything OK Status Monitor works fine.
Brand
Posted on Sep 17, 2008
Hi is there some one out there to help me .epsom r320 will not work on my laptop needless to say i am runing vista home .dont want to buy a new printer as this one has had no use .pleas let there be some one out there.thanks doojang
Posted on Jan 26, 2009
Download the installer epson stylus photo r200
Posted on Sep 02, 2008
Hi just uninstall your printer then go to epson web site and down load
EPSON EasyPrintModule {v.3.10:} 23-Jan-2008, 2.48 MBs
(epson 320037 aplication) and install it.
Then the status monitor works
Posted on May 18, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: Epson Stylus Photo R200 and R320 Status monitor in Vista
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Posted on Oct 12, 2009
After changing the ink, the red light is still on.
epson stylus photo R200 printer the two red lights are flashing can get it to work help
Jul 18, 2010 | Epson Stylus Photo R200 InkJet Printer
Hi My Epson Stylus R200 print is nearly unreadable. The status monitor says status is OK and the nozzle check is fine
Ensure the nozzle check has 6 colours if it doesn't you will need to try head cleaning. you may also need to align the print head. All this can be found in the same place as the option for nozzle check.
If that is ok try a different paper type, ensure you are using relativly fresh ink.
Feb 02, 2010 | Epson Stylus Photo R200 InkJet Printer
Epson stylus photo R200 status monitor in Windows 7 is'nt highlighted ink is low can't tell which ones
Uninstall the current driver and Status Monitor, once uninstalled connect and power the printer on to install the Windows 7 In box driver. If that does not work then you can tell which cartridges need replacing using the printer itself. Lift the lid and press the red ink button once. The carriage will move to the left and stop by a pointer. This will point to the cartridge that needs replacing. Repeat until it is in the change and then change the indicated cartridge/s and then press again to complete the change.
Jan 27, 2010 | Epson Stylus Photo R200 InkJet Printer
The epson R200 isn't supported in Windows 7. That's why the status monitor doesn't work.
Dec 28, 2009 | Epson Stylus Photo R200 InkJet Printer
Jul 05, 2008 | Epson Stylus Photo R220 InkJet Printer
HOW TO INSTALL MY EPSON STYLUS PHOTO R200 I DONT HAVE THE DISK OR CD AND I HAVE WINDOWS VISTA
Try visiting Epson website...look for support link for drivers...then find your printer and operating system...download drivers and install....install program should provide directions..generally it will direct you to make sure printer cable is not connected to pc until install program tells you to do so. You can also do a google search for "epson stylus photo r200 drivers for vista", chances are you'll find a site from the results...good luck
May 22, 2008 | Epson Stylus C46 InkJet Printer
Printer spooler not running
try this :
click start -> run -> type services.msc then hit OK
look for the spooler service and turn it on
Dec 14, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
3,106 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
