Question about NEC MultiSync LCD1720M (Black) 17 in. Flat Panel LCD Monitor
When I first turn the power on my 1720M monitor, the power light blinks and there is a periodic click each time for 7-10 minutes or more before the screen starts flashing alternating colors. If I do not then wait another 30 minutes or so, when I turn on the computer, as Windows is loading, the screen goes black again with the blinking and clicking power light. Turning the computer on first does not help - if I then turn on the monitor, it never gets past the blinking and clicking power light. What's going on here?
  • 103 Answers
SOURCE: Monitor shutting off with blinking standby light.
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Posted on Mar 22, 2007
  • 86 Answers
SOURCE: LCD Monitor picture cutting out occasionally.
Your CCFLs might be going bad. CCFL stands for Cold cathode fluorescent lamps. These are the lamps that provide backlight for the LCD Monitor. These lamps do not last forever, and are a very common part to go bad. The circuit that provides the power for the CCFL is called the inverter, it might be going bad, but I still think it is the CCFL. Only trained techs should try and replace a CCFL or fix an Inverter. CCFLs do contain mercury, but only small amounts.
Since the monitor works for a few minutes and then goes dark, this tells me you have a problem with the backlight function. I have seen this several times, and I do work on LCD monitors professionally.
http://en.wikipedia.org/wiki/Cold_cathod...
My advice, get a new LCD monitor and sell your bad one on ebay.
Posted on Nov 16, 2007
bluenadas
  • 203 Answers
SOURCE: power lite blinks red and will not turn on
Sounds to me like you're experiencing an issue with the power supply in the unit.
Posted on Nov 21, 2007
SOURCE: monitor blinks on and then off and does not come back on until
no, never got a solution
Posted on Feb 05, 2008
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
Why is my Samsung ln-t1953h takes 5-10 minutes to power on. During boot the red light is blinking and clicking.
How old is the tv set also do you have it plugged up to a power cord? Can you tell me how many times does the light blink thank you.
Aug 19, 2014 | Samsung LN-T1953H 19 in. LCD HDTV
When I awaken my NEC LCD 1720M the monitor green light just blinks for awhile before the picture finally comes on.
hi, try downloading and reinstalling the drivers, and also the manual for possible clues as to what's at fault.
MultiSync LCD1720M
http://www.necdisplay.com/SupportCenter/Archive/
Sep 18, 2008 | NEC Computers & Internet
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
My VG800 will not work when first turned on. The indicator light turns green and then blinks on and off with a slight popping sound at every blink. After a period of time, the monitor just starts...
Please check the AC adapter first to see if it is putting out the correct DC voltage with load connected, I do not remember if the power supply has an indicator light on it, see if it is blinking.
Caps in power supply do go bad but you will not be able to fix it.
http://s807.photobucket.com/albums/yy352/budm/Bad%20capacitors/?action=view&current=badcaps2.jpg
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG800/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 19, 2011 | ViewSonic VG800 18" LCD Monitor
It turns off after 10 minutes working
When you say it turns off, is the power light going out too?
If the power light is still lit when the screen blanks, it may be a faulty backlight inverter.
After 10 minutes elapse and the screen goes out, if you power it back on, do you get another 10 min, or does it last a much shorter time period, or not at all?
Your best bet is probably simply to buy a new monitor, and sell yours as "broken" on eBay, I'm sure someone out there capable of fixing it would be willing to pay pennies on the dollar to subsidize your replacement screen.
Jul 03, 2009 | Gateway FPD1965 19" Flat Panel LCD Monitor
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Power light going to blinking amber
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
Jan 01, 2007 | Videoseven R17PS 17" LCD Monitor
NEC MultiSync LCD1720M (Black) 17 in. Flat Panel LCD Monitor Logo
42 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
