Question about Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner
Whiel vacuuming i accidentally vacuumed over the cord and it got stuck around the brush and it melted down to the wires. After taking the brush off and removing the melted rubber I put it back together and now when I turn it on it sounds like the brush is hitting somewhere in that area its a steady thud sound as it goes around. What could be wrong with it? Thanx, Dawna Blevins
  • 710 Answers
Before you do anything, did you wrap the wires with electrical tape? If not, you could get shocked, or at the very worse, burn it up.
As far as the thud sound goes, it sounds like you might have bent the brush and it's rubbing on something where it's bent. try to straighten it. Otherwise, are you sure you got all the rubber out?
Good luck.
Handie Andie
Posted on Mar 25, 2011
  • Kb Wilson Jan 13, 2014
    You might check the belt, it may have a worn area that makes a noise when it passes the motor or brush.
The brush will not spin any more. What can I do?
It sounds as if: -
  1. The belt has broken between the motor and the brush, or
  2. The brush bearings have become clogged with long fibres or hair and have jammed.
Turn the vacuum off and remove the plug from the electricity outlet. Wrap up the cord so that it cannot be accidentally switched on.
Turn over the vacuum and look at the brush. Can you turn it by hand? If yes, the belt has either broken or slipped off. You could buy a replacement part and fit it yourself if you are handy with a screwdriver or take it to a local vacuum repair shop. It should take less than an hour to fix.
or,
Turn over the vacuum and look at the brush. Can you turn it by hand? If No, then check the ends of the brush where it sits in the body of the vacuum. Are there fibres or hairs sticking out at either end?
You will need to remove these hairs and fibres until the brush rotates with some resistance.
Hope this gives you some place to start.
Mar 30, 2015 | Vacuums
My brush is not turning and the belt is on the motor. I think the belt motor may be bad due to excessive dog hair. How do I get to the motor?
I had one melt the plastic around the bearings on the brush. you might try taking out the brush first, getting to the motor you'll have to take it completely apart.
Feb 27, 2015 | Bissell Lift-Off(R) Revolution(R) Turbo...
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
I got a cord wrapped around the roller brush and after removing it the roller brush won't turn.
should have smelt a rubber smell at the same time. The rubber belt probably melted in half. Just flip vacuum over so you can see the bottom. look for arrows pointing to clips or screws. Usually requires removing one panel and the brush. Buy new belt (look on vacuum for correct size or take make and model and name to the store). Just reinstall, replace brush and cover and screws and your all good.
Feb 15, 2011 | Electrolux 5740 Upright Vacuum
Cable is stuck in the vacume s 1361 hoover
Unplug the vacuum from the wall. Disasemble the brush assembly. Usally there are 2 screws, one on each side. Manually reverse the brush and dislarge the cord. Inspect the cord to make sure its not frayed or exposed wire before reusing.
Ed " Original Radio Man"
Nov 20, 2010 | Hoover Vacuums
I got a cord wrapped around the roller, and now neither the roller nor the suction work...only hot air coming out the top of the base.
To unrap the cord from this vacuum you will have to do the following:
First turn the vacuum upside down and place head on counter and handle on the floor. You will have remove the base plate. There are 3 screws that hold it in place. Since cord is wrapped around the brush roller you will not be able to take it all the way off, but it will give you access to the brush roller. If the belt is still on the brush roller, I suggest you cut it, so you can lift the brush roller out of the base and that will make untangeling the cord easy. If you need a new belt here is the info on that.
Style "R" Extended Life. Eureka Part #61110 - Free Shipping Style "R" Extended Life cost is $ 9.99 for one
Apr 29, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
There is suction to the vacuum, however the brush will not turn. Any suggestions?
there is also a small reset button on the outside of the head next to the brush that you can push to get it to start spinning again. dont know officially why its happens, but i would think its there as a safety switch in case something gets stuck
Sep 25, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Ran over cord and the vacuum shut down, won't
sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Cord will not remain OUT..keeps slip-sliding back in
The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner Logo
105 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
