Our printer's roller (8 inches wide, approx and 1.5 inches thick) appears to be ruined. The clear coating has become brittle and the rubber from the roller is coming off onto the paper as it goes through or jams. Do you understand which roller I'm talking about and if you do, can you give me a part number and price? This roller is found under the place where the toner cartridge fits into the back of the machine-towards the bottom of the machine. We are trying to determine repair costs.
    Genius:
  • 1,288 Answers
You don't say which model this is, so difficult to advise specifically..
You are referring to a Fuser Roller, this is subjected to very hot temperatures as the toner is baked onto the paper. What is happening is that the protective teflon coating on the rubber has decayed and the softer rubber underneath is going frissile. From experience with laser printers, photocopiers and print driers, if one roller is going, the rest will be on their way out also. Assuming you can get the part, and fit it, the repair job will be short lived as other rollers will shortly decay.
The cost of replacement varies but depending on the model, between 50 and 80 pounds seems to be the going rate on ebay
Posted on Mar 25, 2011
Canon Pixma MX300 printer had a paper jam. I took out the paper, and it was all there with no missing parts. It continues to say there is a paper jam - there appears to be no reason for the jam. I...
Try checking that a foreign object is in the paper feed rollers- do this by inserting a thin piece of plastic about 2 cm wide through the rollers from the paper exit side. Plastic like that from a shirt box (about 2cm wide by 20 cm long and 1 mm thick works well. I have solved this problem many times with my mx300 and it clears out objects which have droppped into the paper feed, such as Pens , yes pens. and paper clips etc which are otherwise hard to detect on this printer.
Sep 25, 2010 | Canon PIXMA MX300 All-in-One Printer
1/2 inch wide black line appears on the copies
Please use the link provided below to download the user guide. The user guide and the troubleshooting guide will have detailed steps to solve this issue.
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PSC%201510-_E
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Allignment is off on a lexmark x6150
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Press the "Options" button 9 times. "Maintenance/Align" should now appear in the display screen.
2. Press the "Right Arrow (+)" until "Test" appears.
3. Press "Select."
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 14, 2009 | Lexmark All-in-One Printer with PictBridge
Color prints have two strips of toner that will rub off.
Fixed the problem with the advice of one of your members!
Thanks
Jan 30, 2009 | Konica Minolta magicolor 2430 DL Laser...
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Canon ir 400 copier
Check the scanner. If the lube has dried up it could be causing the scanner to vibrate slightly when reading the image.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
Paper jam
Lift up the printer front a few inches using a book or a small box. The paper will them feed beautifully downhill into the roller.
Richard
Oct 12, 2008 | Samsung CLP 300 Laser Printer
Laserjet4 plus
I have actually paid for this problem to be looked at, only to be told that I need a new toner cartridge. Replace the toner first, then, if that does not solve the problem, try wiping the sponge roller with a clean dry lint-free cloth. The sponge roller is the just beyond the metal at the bottom of the area where the toner sits while installed. You will need to remove the toner to see the sponge roller. DO NOT touch the sponge roller with your bare fingers. I recommend wearing clean, powder free disposable gloves.
Apr 21, 2008 | HP LaserJet 4 plus Printer
How do I clean the Fuser Roller
Metho.
No use inkjet stuff in laser machines.
May need to replace Fuser.
Dec 25, 2007 | IBM Infoprint 8 Laser Printer
Paper won't feed
I replace feed rollers when this happens but you guys might want to try a slighty damp rag on the probally covered in paper dust feed roller.
Location underneath with cassette out.
Appearence larger Black Rubber cresent shaped roller inch wide front middle under.
Use damp rag water/metho
Nov 05, 2007 | Brother HL-2040 Laser Printer
k24674
jasbo
jasbo
