Question about Dell Printers:Dell MFP Color Laser 3115cn
I need to replace my replace the fax board on my Dell 3115cn laser printer. I have a replacement board but cannot figure out how to open the printer to replace the board. Can you help?
SOURCE: Dell 5100cn Laser printer with 016-370 restart printer
What do you mean by "not take the download?" Are you trying to load the drivers from the Dell site and have the printer work? I ask because I could not get mine to work with just the drivers offered on the web site. I have to use the original install disk when loading to a machine using Windows XP SP2. Vista on the other hand started running with the downloaded drivers just fine. Have you used the install disk that came with the printer? I am on a home office network but had the same result when I ran a USB cable from my pc directly to the back of the 5100cn. The disk is the only way I can load it and I have had to do it several times over the years when changing the settings on the network. Hope this helps.
Posted on Jun 16, 2008
tipstir
  • 67 Answers
SOURCE: Dell 5110cn Laser Printer Problems
Have you replaced the fuser?
Have you replaced the toner?
Have you order a PM KIT? Most of these kits also comes with the fuser , transfer roller. or imager?
These items above should be replaced.
Posted on Jul 28, 2008
SOURCE: error on all in one laser printer dell scanner error
take it back to the company where you purchased it at!
Posted on Mar 06, 2009
  • 217 Answers
SOURCE: dell 3115cn cyan cartridge still shows as empty after replacing
I'm assuming that the cartridge is a remanufactured item (or a home refilled item.
The chip on the cartridge probably hasn't been changed.
Posted on Aug 30, 2009
  • 547 Answers
SOURCE: Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Posted on Jan 27, 2010
Testimonial: "Thanks! I have gone through all the instructions on Tech support for the printer. All cartridges have been cleaned and drum has been cleaned. Guess "
Error code 093-921
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Mar 02, 2016 | Dell 3130cn Color Laser Printer
I am getting error 133-290
This a Dell printer. Get support at: http://www.dell.com/support/home/us/en/19/product-support/product/dell-3115cn/manuals
May 07, 2015 | Laser 3115cn All-In-One Printer
How can reset all setting dell 3115 cn
"Here is what I did to reset the Dell 3115cn Laser Printer. In the users manual for the 3115cn in section 6 "Changing System Settings" "Resetting Defaults" refers to page 64 where it says, " For more information, see "Reset Defaults" in the User's Guide. Only I did not get a User Guide with my Dell. So I Googled "3115cn user guide" and downloaded it to my desktop and then went to Resetting Defaults. In the attachment "Initializing NVRAM for Network Settings" is what I did. Hope this helps someone else."
May 07, 2014 | Dell 3115cn Multifunction Color Laser...
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
"009-362 Printer, Restart Printer, Reseat c cart., contact support"
The Cyan Toner Cartridge is either not seated correctly or the cartridge is bad. Open the front of the printer, pull out the Cyan Toner Cartridge, reseat making sure it fits all the way to the back.
If the problem is not resolved replace the Cyan Toner Cartridge.
Oct 21, 2010 | Dell Printers:Dell MFP Color Laser 3115cn
156 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
