Question about Polaris 180 In Ground Pool Cleaner In Ground Pool Cleaner
Just got a new polaris 180, assembled it and tried to make it resemble the old one that came with my pool. Problem is, the front of the hose gets wrapped around the front of the Vac and the bag, causing it to not vac properly. Soloutions?
    Top Expert:
  • Polaris Master
  • 7,897 Answers
Re adjust bag to hose
Posted on May 22, 2016
SOURCE: Front wheels don't turn
It's probably a damaged drive gear. Polaris was at one time giving out free repair kits for this problem because of the poor design of the original.
Posted on Apr 21, 2009
  • 4 Answers
SOURCE: Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Posted on May 10, 2009
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
  • 128 Answers
SOURCE: polaris 180 pool cleaner is running slow and not
Hate to say it but they don't make them anymore. Spend the money and buy a Polaris 280
Posted on Aug 23, 2009
john224
  • 1378 Answers
SOURCE: Installed a new 3/4 hp Polaris pool sweep pump.
Those pumps are dual voltage...Are you certain you connected it correctly for the voltage present? If the motor is set up for 230V (as it usually is when purchased new) and you only feed it 115 volts it will heat up and then act as you are describing. The side of the motor will have a diagram for how to reconnect the motor if necessary.
If connected correctly you would have a voltage issue in the line to the pump (unlikely). Check the voltage present at the motor terminals under load and look for a drop of more than 10%. If this is the case you will likely need an electrician.
Like I said though, it is usually because of wrong voltage setup for the problem you describe.
Posted on Dec 19, 2009
Running slow dont ' t pic up trash
check filter on sidewall fitting if ok check inside to see if a hose came off
Apr 10, 2014 | Polaris 180 In Ground Pool Cleaner In...
Polaris pool clener sweeper not moving
if water pressure ok check inside for hoses off or belts broke
Apr 21, 2013 | Polaris 180 In Ground Pool Cleaner In...
It does not pick up debris and there does not seem to be any suction on bottom of unit
Try these troubleshooting techniques for this automatic pool cleaner. First, check the thrust jet and make sure that it is getting proper thrust. Check the filter screen in the in line filter and clean it is necessary. Make sure that your skimmer basket and pump basket are clear of obstructions. Check your hoses and connections to make sure that you don't have any leaks. A loss of water pressure could be your problem.
Jun 09, 2010 | Polaris 180 In Ground Pool Cleaner In...
Will not pick up the trash. Seems to have no
The 180 is a pressure system not vacuum. You must have good pressure for it to work properly. First clean your filter thoroughly. If that doesn't correct the problem, look for leaks in the hose.
May 12, 2010 | Polaris 180 In Ground Pool Cleaner In...
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 180 pool cleaner is running slow and not picking up trash
Jul 03, 2009 | Polaris 180 In Ground Pool Cleaner In...
Polaris 180 In Ground Pool Cleaner In Ground Pool Cleaner Logo
44 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
