Question about Garden
Bit is stuck and cannot remove it. Have tried pretty much everything.
  • 710 Answers
This was posted under chainsaws. If you are asking about a router bit, I have found that taking the collet out with the bit still in it and putting it in a vise. Tap from the bottom with something and it should come out. Be sure to have something underneath to catch the bit. I have done this and had the bit fall and break on the floor...
Please post back if you aren't asking about a router.
Handie Andie
Posted on Mar 25, 2011
How to remove bit stuck in kango drill
Hello, You might try spraying some wd-40 in the chuck to let soak and loosen up, to be able to turn and remove the bit.
May 15, 2014 | Drills
32'' insignia TV volume stuck down
This may turn out to be a failed component internally.
Dec 31, 2013 | Insignia Televison & Video
Handwheel stuck
most likely the bobbin thread is wound around the components.
remove the bobbin and check for a mass of thread cut it all away and remove every last bit then it should work
Dec 28, 2013 | Janome Hello Kitty 11706 Mechanical Sewing...
How do we remove the laterals, they seem to be stuck
Hi, I just did mine and they had never been removed (12 years). Mine were also stuck so first, I sprayed a small quantity of WD40 at the base of each lateral and went for lunch. Then I rinsed everything as best I could with clear water to remove as much sand and gravel. I then used hot water to rinse again and they unscrewed pretty easily. Have fun!
Apr 21, 2013 | Hayward Pool & Spa
Cannot remove sdsdrill from chuck
If it is stuck you may have to cut the collar (item 139) that you push to release the bit. I use a dremel tool and cut through once on each side. Once that is removed you will see the spring, plate, and ball that hold the bit it. You just need to remove the ball. If it is still stuck then it is stuck in the spindle itself (item 149). You may get lucky and be able to use a punch and hammer to hit the spindle end while holding the bit in a vice. A helper to hold the tool is recommended when doing this method, If you still can't release the bit from the spindle then it has to come apart anyway. Here is the parts diagram. I didn't find the exact model you listed but they should all be pretty close. The bit retaining method is a pretty simple design and easy to work on.
DeWalt D25003K diagram
Aug 15, 2012 | Dewalt Drills
Where is the battery in my 2007 bmw 328 sports wagon located?
  • The battery is in the trunk. You need to lift up the carpet against the back right portion of the wall of the trunk. That cover is on pretty good and takes some force to break it free as them tabs are stuck there pretty good. Mess with the cover a bit and it will come up. Then there is a bar that removing a couple of nuts will let you remove and then the cables can be removed.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 08, 2011 | 2007 BMW 328xi Sports Wagon
How do I take apart the strainer section?
Everything should just lift up and off. May be
juice stuck together. Try a little tap to the whole
assembly.
Mar 04, 2010 | Acme 6001 Juice Extractor
Trying to change the clutch, having trouble getting the transmission off. Hoping for a picture of transmission on vehicle
Look everything over carefully. Did you remove all the bellhousing to engine bolts? Have you removed the starter and the splash pan at the lower front of the bellhousing? Sometimes the locating pins on the engine get a bit stuck and it needs a bit of coaxing to get it loose, but providing you have everything unbolted, it should come apart!
Apr 13, 2009 | 1998 Jeep Cherokee
Can't remove the battery door
try a flat-bit screwdriver and open it up
Dec 15, 2008 | Motorola Mobility RAZR V3
Can't plug in the charger.
Try gently dabbing a bit of vegetable oil onto the mud - try and get the mud saturated but dont stick the phone in a bowl of oil. Depending how much clay etc there is in the mud, this should soften it up enough to clean it out. remove the battery before doing any poking around in the hole, and use something a bit stronger than a matchstick (metal is not ideal) hunt for something made of strong plastic. Be patient, you may have to dig it out bit by bit. Hope this helps, if the oil doesn't soften the mud enough then please ask again, there are other more dangerous ways to do it :)
Jun 29, 2007 | Sony Ericsson K750
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
