Question about Refrigerators
I have a GE Profile arctica model pss25ngna bb serial gd404096 cant keep tempiture set in the frige part freezes everything water in door freezes wont make ice
5 Suggested Answers
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
  • 121 Answers
SOURCE: I have a GE Profile
This could be a fan motor problem. Check to see if the fans are running and if not take a look at this page http://www.appliance-repair-it.com/refrigerator-fan-motor.html
If the compressor is not running this page will help http://appliance-repair-it.com/GErefrigeratorrepair.html
There could be a defrost problem, look on the back wall of the freezer to see if it is covered with heavy frost. If so your problem is that it is not defrosting. This page will help http://appliance-repair-it.com/GE-refrigerator-repair.html
Posted on Sep 20, 2010
SOURCE: GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Posted on Jan 31, 2011
ddsgamer
  • 5 Answers
SOURCE: GE Profile Arctica Model PSS25NGNA CC Hi, I noticed that water was leaking out of my water dispenser. Upon opening the freezer I noticed that everything was thawed out. The doors had been closed and t
you ended with the fan starts to run ? check the coils there should be a fan that blows across the coils sometimes the fan gets to dirty dusty clean that out and make sure that it works it must be running to keep the gases from over heating also clean the coils as will help big time
Posted on Oct 22, 2012
Oct 22, 2012 | Refrigerators
Nov 26, 2009 | Refrigerators
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
I have a GE Profile Arctica Side By Side refrigeratorand the water despenser is not working. I have narrowed the problem down to be a frozen waterline, but it is not frozen in the frezer door. The line is...
There may be an issue with the water dispenser line freezing in this model. The fix for it might be this dispenser water tube heater kit # WR49X10173. Hope that helps you out and best of luck
http://tclaundryrepair.com/
Feb 25, 2009 | GE Profile¿ Arctica® Energy...
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
