Canon mg6100 printer scanner...open the lid to change cartridge...lid won't close
Just push it down, It feels like it is stuck up, but just push it down it will go
Posted on Apr 19, 2011
How to fix 5011 error on canon MX 366
1 . TURN OFF THE PRINTER
2 . OREN THE LID INCLUDE SCANNER
3 . RESTART PRINTER WITH OPEN LID
4 . THE CARTRIDGE MOVE TO MIDDILE
WHEN ERROR MESSAGE IS GONE CLOSE THE LID TRY TO PRINT
May 08, 2014 | Canon Pixma MX420 All-In-One Printer
E05 problem
Canon Pixma MP270 error E05
Apr 22, 2014 | Canon Pixma MP270 All-in-One InkJet...
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
How do I change the cartridge for Canon 250...Cannot get to the cartridges
To get to the ink cartridges pull up on the front of the printer just below the scanner lid. There should be a "handle" for you to grab at. Once you lift that up the ink cartridges should move to the center automatically. They will return to their original position after 10 minutes of the lid being open. Replace the cartridges by pinching the latches on top of the cartridge holder and then pressing the new ones in. Close the lid when you are done.
Also, the quick start manual for this product is located here: http://gdlp01.c-wss.com/gds/4/0300002294/02/MP270_MP250_GS_U2_V1.pdf
And the on-screen manual is located here: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#BrochuresAndManuals
Apr 22, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
How do I change the ink cartridge
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The print cartridge carrier moves to the center and stops at the loading position. Grasp the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges and install the new ones. Snap the lids closed and lower the scanner unit to close.
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Hope this helps. Thanks.
Nov 22, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1150 - how do I change ink cartridge
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center at the loading position. Squeeze the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges. (refer to sample image below. printer shown may not look like your printer, however, the steps are the same.)
Insert new cartridges. Color cartridge should be in the left carrier and the black in the right carrier. Snap the lid closed. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Thanks.
Nov 18, 2010 | Lexmark C533DN InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
Mp145 E5 problem
Cannon has made their ink cartridges in a way that you have to buy new ones every couple of refills.This is a way to bypass that..worked on my MP145.
Reset Ink level Canon Printer Cartridges PG-40, CL-41, PG-50, CL-51, CL-52
To reset the ink Level (method 1)
  1. Paste with a thin strip tape the upper horizontal row contacts
  2. Insert the cartridge into the printer and close the lid.
  3. The printer will now on the move, but wait until there on the screen Your computer is the message that there is a wrong way to a Ink cartridge is loaded. Click OK in the message
  4. Open the lid of the printer and remove the cartridge from there.
  5. Download Now the strip of adhesive tape and paste it contact now on the Second row (from top) horizontal contactjes. (Picture 2)
  6. Insert the cartridge into the printer back again and closed the lid. Weather will The printer is on the move again, and again we place an alert on Your monitor. This time, the message that the cartridge can not Be recognized. Click on OK again
  7. Open the printer and remove now for the last time the cartridge from the
  8. Remove the tape and insert the cartridge in the printer and connect it Lid.
  9. The printer is the cartridge back as a new and indicates that the cartridge full again
Resetting the ink Level (method 2)
Works only in some cases
  1. Paste with a thin strip tape the bottom row of horizontal contact The cartridge off
  3. The printer will now on the move, but wait until there on the screen Your computer is reported that on one wrong way Ink cartridge is loaded. Click OK in the message
  5. Download Now the strip of adhesive tape and paste it contactjes now on the Contact uppermost horizontal row.
  7. Open the printer and remove now for the last time the cartridge from the Printer.
if that doesnt help... u will most likely be required to call canon...
thank you for using Fixya....
A very Helpful rating is appreciated...
have a nice day
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Replace ink cartridge
2 Lift the scanner unit until the scanner support keeps it open.
The print cartridge carrier moves and stops at the loading position.
5 Remove the stickers and transparent tape from the bottom of the cartridges.
6 Insert the new cartridge. Make sure the color print cartridge is
secure in the left carrier and then snap the lid closed.
If you are installing a black print cartridge, make sure that it is
secure in the right carrier, and then snap the lid closed.
7 Lift the scanner unit and push the scanner support back while
Mar 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
385 people viewed this question
k24674
jasbo
jasbo
