Question about Logitech Cordless Desktop EX110 Keyboard/Mouse
Some of my keys on the keyboard automatically does keystrokes I've never seen before for intance, I cannot use "Z" or "A" as whenever I click them the "A" does ALT+F4 and the "Z" is next. Thus I am unable to type those letters on anything. Please help with this problem As I could not find any cusomization on normal keys on the setpoint software. Thanks in advance
sandrew
  • 2961 Answers
SOURCE: The first letter repeats
Go to control panel>priters and other hardware>keyboard, then in the speed tab move cursor to slower side and test in area below. It may stop it from happening, but you would expect it to do it on every keystroke, so it may be sending the first stroke to wake up the keyboard. It may be the keyboard or the sender that is faulty and a replacement to really solve it.
Posted on May 01, 2007
  • 20 Answers
SOURCE: Keys not working!!!
got something stuck under the keyboard keys? Turn the keyboard upside down and give it a good shake.
Check the connection in the back of your PC - make sure none of the pins are bent if it isn't USB.
Posted on Feb 28, 2008
  • 35 Answers
SOURCE: Keyboard keys suddenly stopped working
It sounds like your keyboard has lost "Sync" with the base unit. This happens sometimes. Basically, the "Base Unit" that is plugged into your computer should have a button on it. Press that button. Then on the bottom of the keyboard you should find a button, press that button. Now try using your keyboard. It should work.
Posted on Oct 24, 2008
SOURCE: Logitech keyboard wireless
You need to go to Start -> Settings -> Control Panel & find the "regional & language settings". Set the country and related settings to wherever you are (as you're currently using a foreign setting).
Posted on Dec 04, 2008
cpenzes
  • 1102 Answers
SOURCE: typing is an effort
This is a laptop right
When you open keyboard in control panel those bars are for speeding up or slowing down
right click on my computer then click properties then at the top you'll see restore click that and restore your pc to an earlier date when you know it worked click apply then restart
if that don't help we'll need to try and update driver
Posted on Jan 16, 2009
Wifi problems with Dell Inspiron E1705
LOL, sounds like you didn't hit the correct key or keystrokes.
First of all look in front and on the sides for the Wireless Switch and make sure it is turned on. Then once it is on you can toggle the wireless on or off by Keystrokes. Press and Hold the FN key located at the lower left portion of the keyboard, then hit the corresponding F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of the wireless signal )))) or it will have the icon of a tower with the wireless signal )))). Normally when the correct keystrokes is hit the screen will display Wireless On or Wireless Off.
May 05, 2012 | Dell Inspiron E1705 Notebook
Internal tochpad wont work
You probably have the touchpad turned off. Some models will have a button at the top of the touchpad in the middle that toggles it on or off.
Some models you can tap twice in the upper left hand corner of the touchpad to toggle it on or off.
I've seen some models where the touchpad is toggled by keystrokes. You had to Press and Hold the ALT or FN function key then hit the key that toggles the touchpad. The correct key to hit had the icon of a finger pointing at a touchpad.
Click Start/Control Panel and check the Mouse or touchpad drivers to make sure the settings are ok. I would just set everything back to Default.
Maybe you need to reinstall the touchpad drivers if any of the above does not solve it.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad drivers.
Apr 30, 2012 | Acer TravelMate 2300 Notebook
My friend's touchpad does not work
Some manufacturers made a toggle that is in the upper left hand corner of the touchpad that you tap twice to toggle the touch pad on or off.
Some touchpads will have a button at the very top of the touchpad in the middle that you press to toggle the touchpad on or off.
Some manufacturers let you toggle the touchpad between on and off with keystrokes. Normally the keystrokes is to Press and Hold the ALT or FN function key then hit the correct F1 thru F12 key that toggles the keypad. Normally the correct key that toggles the keypad will have the icon of a finger pointing at a square which represents the touchpad.
You can always try to see what the manufacturer manual says about the keypad.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals.
Apr 20, 2012 | Computers & Internet
Wireless is disabled on dell vostro 1540
Look on both sides of the laptop for the switch or button. Look in the front of the laptop too. I've seen the wireless switch at the bottom of the lcd screen on either the left or right side on some dell models (you just press it).
Normally the keystrokes to get the wireless going requires you to Press and Hold the FN Function key then hit the key that toggles the wireless (F1 thru F12). The correct F1 thru F12 key might have the wireless icon )))) on it.
Mar 31, 2012 | Computers & Internet
Can't use PrintScreen key on Logitech's "Cordless Internet Pro" keyboard. Key is on upper right of keyboard with "Prt Scr" above "SysRq" on the same key. I've...
It's what you do AFTER PrtScr that matters.
Basically the key takes a snapshot of the screen and stores it on the Clipboard. Next PASTE it into an application like Paint and Print from there. Or paste into a document you are working on that requires a screen clip (after editing it, if needed).
Rate me 4 stars is this helps!
Oct 25, 2017 | Logitech 967437-0403 Keyboard
Dell latitude missing keystrokes
I had problem with my Dell latitude notebook where some keystrokes didn't return the keys. I fixed the problem by replacing a new key pad. I found a replacement key pad on ebay. Good luck.
Apr 01, 2010 | Dell Computers & Internet
Doubled accent with single keystroke (using Language Bar)
It's just a glitch that may happen from time to time. The first thing is to reboot, and more likely than not it will be gone.
Dec 16, 2009 | Microsoft K5100141 Keyboard
Dell inspiron keyboard issue?
There is a keystroke combo that enables or disables those keys.
They should work. Can't remember the keystroke, but it's a FN plus one of the keys--should be a symbol on the keyboard.
Dec 12, 2009 | Dell Computers & Internet
Keystroke on shift 2 is no longer @, but "
There's nothing wrong with your keyboard hardware. You want to change your keyboard layout from english UK to english US.
In windows (I assume your in windows)
1. start, controlpanel
2. regional and language options
3. Set the default input language to English US
4. in the box " Installed services " add a keyboard layout for (English United States)
Jan 24, 2009 | Logitech S 510 Remote Control, Multimedia...
Keyboard problem
If its a wireless keyboard, replace the batteries. If its not wireless, try plugging it into another port(if possible) and if it still doesn't work, you probably have a defective keyboard.
May 29, 2008 | Toshiba Satellite P105-S9722 Notebook
Logitech Cordless Desktop EX110 Keyboard/Mouse Logo
32 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
