Question about Roper Washing Machines
The basket seems out of balance, makes a strange noise when spinning. The machine is only one year old. Is there a way for me to open the machine to rebalance the basket or make sure something isn't loose causing the problem? Thanks. Tom
    Brigadier General:
  • 6,277 Answers
It could just be that the machine is not 'balanced'.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 25, 2011
Makes a lot of noise when brakes are put on AFTER the spin cycle , is this worth fixing ?
Put more baby powder on the friction surface. When the brakes get wet, the baby powder washes off and they make incredibly strange noises.
Mar 16, 2015 | Washing Machines
Machine making a knocking noise during spin cycle. The drum shaft has alot of free play front to rear and I suspect that is where the problem resides.
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Nov 16, 2009 | GE WSXH208A Front Load Washer
Spin basket weld gone causing loud knocking on spin cycle
front load washers are a great inovation into our modern society that being said they are a delicate balance of moving parts the main bearing plays a very important roll in keeping the machine balanced during the spin cycle I wouldn,t do one without the other . you're absolutly right too much $$ for a 4 year old machine call Electrolux plead your case and see if the will dicount the price of a new macine at least the value of the basket Good Luck
Oct 09, 2009 | Frigidaire GLTF1670A Front Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
My washer does not spin and makes loud noise
Hi!!! You have a bad motor coupler replace and you should be fine..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Loud noise, then not so loud, but now electrical burning smell and little draining
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin Shake ...
yes the water is supposed to be there, thats called the balance ring, some machine use cement others water. you say the washer is unbalanced even when empty, is there an indicator or is the machine itself physically off balance. if there is an indicator the off balance swich might have gone bad or you might need to adjust the leveling legs.
Jul 03, 2007 | Frigidaire CWS3600AS Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
