Question about Brother HL 5250DN Laser Printer
Help! Red status light and toner light will not go off nor can I print despite the fact I have purchased toner that I didnt believe I neded to begin with.Help
  • 138 Answers
It sounds as if the cartridge you purchased was a remanufactured or self filled. The error light your having is toner cartridge related. The left side (not the side white the white brother label over the fill cap) of the cartridge has a resetting apparatus that resets the toner page count. I have included a link to a distributor site which has instructions at the bottom of the page for resetting the flag on the cartridge to trip the reset again.
If you remove the cartridge and drum from the machine you can also check to make sure the lever on the left sidewall of the printer that resets the cartridge is not damaged. Look 3 inches inward and 1 inch down on the black sidewall. The little lever should flip downward and rebound up freely. I can't remembeber for sure but you may be able to power on the machine with the door open and drum only installed and flip the lever for a manual reset. Not sure now as each brother is a little different. If not, use the link provided below.
Hope this helps you.
http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
Posted on Aug 26, 2008
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
After printing several hundred sheets, status light went red. There was no paper jam. Let printer "cool down" overnight. Status light still red. Drum has never been replaced. Toner light is on. However, in...
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Jul 05, 2010 | Brother HL 5140 Laser Printer
My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Dec 14, 2009 | Samsung CLP 315 Laser Printer
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Can't print because of toner light.
This problem sounded familiar and that's because it is.
Read this and try the drum resetting procedure, it's likely the same:
http://www.fixya.com/support/t466413-toner_light_brother_hl_5250
Aug 12, 2008 | Brother HL 5250DN Laser Printer
Help
I am afraid your gonna have to open it up, forget the electronics - concentrate on the optical/mechanical sensors around the mechanics.
If all else fails buy a Samsung/HP laser printer
Aug 03, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
217 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
