Question about Hoover PE235 Front Load Washer
Which compartment is for popwder and which for conditioner
    Brigadier General:
  • 6,277 Answers
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Methinks you could also do with a manual!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Cheers,
John C
Posted on Mar 25, 2011
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
The conditioner isn't going through my machine
Clean conditioner compartment as you can see on bottom picture.
Be sure to read the instructions of the manufacturer of conditioner. Some manufacturers supply concentrated softener which should be diluted with water (is too dense and can clog small drain tube in softener compartment). Also make sure you do not fill up over sign MAX., otherwise softener may leak in drum before starting the washing machine.
Dado
Oct 10, 2014 | Zanussi Washing Machines
My machine will not take the conditioner into the wash
in this case, do the following test. Since the machine starts to fill water a little pull out dispenser drawer and make sure water intake to softener compartment. There is possible 2 failures. First, clogged the holes for intake water above softener compartment and water doesn't intake to softener compartment. Second, faulty water dispenser so water intake to the pre-wash or wash compartment.
Dado
Oct 06, 2014 | Zanussi Washing Machines
Conditioner won't empty in the compartment in
Conditioner won't empty in the compartment in washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 07, 2012 | Hotpoint Washing Machines
Not emptying conditioner compartment conditioner
Feb 20, 2011 | Hotpoint Aquarius WD63 Front Load...
The conditioner compartment will not empty. Has
Suggest that the water inlet valve faulty or the timer is not sending electric feed to that valve at the time when the conditioner hose requires it.
If the conditioner is partly gone or is wet it could be too little water pressure to flush it down.check inlet valve filter.
If no joy sounds like a job for engineer,, sorry
Feb 23, 2010 | Washing Machines
Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Dec 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Part from drawer compartment has come loose and I don't know where it attaches. During the wash water then comes out of the drawer compartment. The piece is about 6cm long and must funnel water. Can you...
The part you are referring to sounds like part of the conditioner compartment, it syphons the conditioner into the drum on the last rinse, it should fit in the smallest compartment of the soap draw.
Plz rate my solution.
Thanks.
Dec 22, 2008 | Tricity Bendix AW1400W Front Load Washer
How do i fix my bendix washer
hi! you need to un clip orpull the draw out (easy enough!) then give it a good clean, there will be a little tube in the draw that will be gunged up! a pipe cleaner or ear bud wil clean it through, with lots of hot water!
Dec 20, 2008 | Tricity Bendix AW1400W Front Load Washer
We buy a use front load wacher we dont have the manuel it is a 24 inch front load we dont know if we use the same detergent ad softner and were we put it please sent me or phone me 72 581 0294 or e mail...
Any detergent that says "Automatic" should be OK.
Pretty much any softener should be OK.
You will usually find a drawer on the front panel of the machine, just under the top edge, typically on the left hand side.
If you open this drawer, you will find it is divided into a number of (typically four) compartments. There will be one or two large compartments for detergent and one or two smaller, usually partially covered, compartments for bleach and conditioner.
You need to identify which is which.
Starting with detergent: If you only have one large compartment, that's the one to use.
If there are two, you need to know which is for main wash and which is for prewash. If one is bigger than the other, use the big one for your main detergent load. If using a cycle that does a prewash, put detergent in the smaller compartment as well.
If they're both the same, you need to experiment: Select a wash cycle that doesn't do prewash. Turn the machine on, and when it starts to fill, cautiously open the drawer a little and look to see which compartment has the fill water running through it. That's the one you need to use for your main wash detergent (use the other as well on cycles that do a prewash).
Now look at the smaller compartments. Hopefully, they'll be marked with a triangle for the bleach and something looking like a flower for the conditioner. If not, put a little bit of conditioner into the bottom of each, set the machine to "final rinse" and see which compartment it takes the conditioner from. That's the one you use for conditioner in future. (Don't worry about the little bit of conditioner you've put in the bleach tray - this will rinse out the first time you run a full cycle).
When putting in bleach or conditioner, it's important not to overfill. If there's a fill level line, don't go above that. If the compartment is covered with a grating then fill no further than the grating. Overfilling will cause the product to go into the machine too early in the cycle.
(Finally, strongly advise against posting your phone number or personal email address on public internet sites - it attracts all sorts of undesirable attention)
Good luck - and enjoy your new machine.
A.
Mar 15, 2008 | Washing Machines
Hoover PE235 Front Load Washer Logo
50 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
