Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
CABRIO WASHER DL ERROR
  • Anonymous Sep 13, 2008
    same problem
    Novelist:
    Champion:
  • 261 Answers
DL or F 83 is a door lock issue. Make sure the light is off before opening the lid and also check where the lock is for build up a gunk.
Posted on Sep 20, 2008
My cabrio was on the final rinse and spin..it is now stuck at 15 minutes..washer is full of water and clothes...dl is the error code..I have turned the power off and turned it back on, I am able to pull...
'dl' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
WHIRLPOOL CABRIO DL ERROR
The DL is a door lock error but it can also mean an error with communication to the main control board o
First try to unplug all your connections to the main control board and plug them back in and try it again.
Sometimes a wire harness just may be loose.
If that does not work.
You need to replace main control board .
SAM ANDERSON
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Im getting a code of dl when i start it up...than it just peeps and nothing else happens
dl means door lock error you have to replace the door lock switch cheapest supplier might be marconeappliance parts
Aug 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WASHER WILL NOT SPIN dL KEEPS COMING UP
dL error - means open door lock switch with motor running, what you need to do is unplug unit for 30 mins, then try again
Jan 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting a DL on the top load washer
The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DL indicates a problem with the door lock mechanism. See the section on troubleshooting and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Dl error will not clear
My Whirlpool cabrio is making a humming noise an the water filled the tub but wont drain i tried pressing buttons but no luck please help,how do i reset it
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
267 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
