Question about Hisense TL-3220 Television
I have a hisense hydfsr-a205e tv. The remote stopped working. I changed the batteries and the remote still lights up but the tv doesnt turn on.
  • 11800 Answers
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Posted on Jun 04, 2011
  • 13433 Answers
SOURCE: hisense tv
so whats the remote you have there?
Posted on Oct 23, 2008
marked
  • 6487 Answers
SOURCE: hisense tv
Try this code 142, inform us for any updates.....
  • 11 Answers
SOURCE: Hisense TL2020 - Won't come on.
Lay unit flat on table, remove stand and rear cover. When you remove back, you will see a power supply board in the middle of the set.There are (3)1000mfd @25 volt electroltics and (1)220mfd @16 volt electrltyic that have to be replaced to return to normal operation. This is not something to try if you are a novice as you must observe polarity when installing these caps. But this repair WILL return set to normal operation.
Posted on Aug 08, 2009
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
Regular hisense TV 42 inch remote stopped working need to change input buttons on bottom help
Hi
Anonymous, It is the remote hand set which goes bad. Please have the hand set checked for defective crystal oscillator, old batteries, and failed IR LED. There may be some internal damage due to falling also.
Jun 13, 2015 | Hisense Televison & Video
Hisense T.V HYDFSR-0076ET .looking for a universal remote code
0375,0338,0397,0341. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Televison & Video
Hisense tv factory reset :
To do a factory reset; you should enter its service mode option. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Service mod entry, adjust and exit procedure to many popular brand TVs are given in detail.
Jan 23, 2014 | Televison & Video
I am looking for remotes codes to program my universal comcast remote. I have a Hisense remote HYDFSR-A205EA
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
Nov 09, 2010 | Hisense Televison & Video
I need the code to program a rca systemlink3 remote for a hisense tv
0748...but if its like mine it wont work. these HiSense remotes are JUNK!!!
Aug 17, 2009 | Televison & Video
Locked remote
i know this may sound silly but check the batteries. now if you allready changed them and your still having the same problem check the ir signal on the remote. now all you have to do is take any camera( camera phones work just as good) hold it to the ir sender on the remote press any button on the remote and look through the view finder on the camera. you should now see a light go off on the remote through the camera. if you dont see a light then you have yourself a broken remote. if you do then its possible its the tv ir reciever. and may need to be serviced. but hoping its the remote you can always get a replacment remote for cheep.
Jan 26, 2009 | Hisense TC24FS2H TV
Hisense remote does not work with hisense tv
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Apr 29, 2008 | Televison & Video
Televison & Video Logo
333 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
