Question about Cakewalk Music Creator 2 for PC
Failed to update the system registry try using REGEDIT
Wat does regedit means
regedit is an an inbuilt Microsoft Registry Editor. To start the regedit.exe go to Start>>>Run>>> type regedit and click OK. The Microsoft Registry Editor (regedit.exe) enables you to view, search for, and change settings in your system registry, which contains information about how your computer runs. Although you can use Registry Editor to inspect and modify the registry, doing so is not recommended, because making any incorrect changes can damage your operating system. Please go to http://en.wikipedia.org/wiki/Windows_Registry for more details.
Mar 22, 2012 | Acer Computers & Internet
Mx3560 laptop- the cd/dvd rom does not work but device manager says it is OK. Audio cd will not play. rom keeps clicking but does not play. downloade and updated drivers from gateway site
try this one:
if you are using windows XP
- click start
- click run, in the run type in regedit
you will see a registry editor window
in the registry editor window
- click the + sign at the hkey_local_machine
- click the + sign of system
- click the + sign of currentcontrolset
- click the + sign of control
- click the + sign of class
there will be bunch of random letters and number under that control
try to find this one
{4D36E965-E325-11CE-BFC1-08002BE10318}
if you click this check if you will be able to see DVD rom at the right side of the registry editor window
you must delete the upper and lower filters
after that restart the computer and try to put in dvds
for vista or win7
- click start and type in the start search regedit
after this just do the same thing with the win xp instructions
try also to update the DVD codec. you can also try to download the most updated windows media player, power DVD or any software/program that have dvd codecs or that acts like a player for DVD
i hope this works.
Pls rate my resolution thanks!!
Mar 05, 2010 | Computers & Internet
Drive Failure.... AGAIN
maybe its not the drive maybe its the software just try this one:
- click start
for vista or win7
i hope this works.
Mar 04, 2010 | Tascam CD-RW2000 Burner
MY DVD DRIVE WORK IN CD AND VCD BUT NOT WORK IN DVD
try this one:
- click start
for vista or win7
i hope this works.
Feb 26, 2010 | Acer Computers & Internet
Could not read the disc on my W11 aj
try this one:
- click start
for vista or win7
i hope this works.
Feb 26, 2010 | Computers & Internet
Message Failed to update system registry. Please try using REGEDIT also,Photo explorer won't synchronize album, program not responding message
This site explains all about REGEDIT.Is this software compatable with your system?Somewhere on the box is system requirements.It will tell you what OS it supports,what speed (in Ghz)processor,How much memory,and how much space on your harddrive is needed. You may even need a Graphics card,so check it out .
Uninstall the software with an uninstaller like REVO UNINSTALLER here.
http://www.revouninstaller.com/
This is a free utility that will 100% remove the old software for a clean installation.
Make sure your OS is supported,check with the manufacturer for the latest drivers and updates.
Feb 23, 2010 | Novatel Nova Development PhotoImpact® Pro...
The drive does not reads any disc inserted
try this one:
- click start
try to find this one:
for vista or win7
i hope this works.
Feb 22, 2010 | Computers & Internet
Reads only cd
try this one:
- click start
for vista or win7
i hope this works.
Feb 20, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
LG Z1 the cd dont works
try this one:
- click start
for windows vista and windows 7
- click start, type in the start search regedit
after this just follow the instructions with the windows xp
if that doesnt work, try to update the DVD codec.
i hope this works.
Feb 20, 2010 | Computers & Internet
I've installed a couple of programs and get a "regedit" error to "update". How do I update the regedit?
Hello,my friend regedit is system registry editor.The message you received says that your program was unable to be installed because regedit failed to update (manipulate/edit) the system registry.So find out which program u have installed is not working properly,uninstalled it and the next time you want to install it try right click and run as administrator.
Feb 06, 2010 | Toshiba NB205-N311/W Netbook
Cakewalk Music Creator 2 for PC Logo
239 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
