Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
What is the cu ft of the Maytag washer model A210
Jimster
  • 240 Answers
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
Posted on Jun 01, 2008
onthejob5130
  • 640 Answers
SOURCE: What is the capacity of a my washer.
4.2 thats about 26 pounds
Posted on Jan 04, 2009
tzweeb
  • 318 Answers
SOURCE: trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Posted on Jan 31, 2009
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
  • 10865 Answers
SOURCE: What cu. ft. size is my Whirlpool top loading
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Posted on Jul 28, 2009
MHWE200XW00 Accidentally unplugged unit while in cycle. Have technical sheet, ran diagnostic test, F1 E1 shows and 3 beeps. Released door manually. Clicking noise = power to CCU. Reset the computer?
Troubleshooting - Maytag MHWE200XW Use And Care ...
www.manualslib.com > ... > MHWE200XW > Use and care manual
Maytag MHWE200XW Manual Online: Troubleshooting. of a service call... In U.S.A. www.maytag.com/help In Canada www.maytag.ca ? Did you empty pockets.
Maytag 3.5 cu. ft. Front Load Washer (MHWE200XW)
www.searsoutlet.com > Washers & Dryers > Washers
Shop for a Maytag 3.5 cu. ft. Front Load Washer (MHWE200XW) (MHWE200X) at Sears Outlet today! We offer low prices and great service.
Maytag , Whirlpool Washer Repair - Drain pump error, no ...
? 4:29
https://www.youtube.com/watch?v=QMRIPmrlAkI
Jul 2, 2013 - Uploaded by ApplianceVideo.com
Service a Maytag Washer suffering from this following dilemmas: Drain pump error f9e1 At: http://www ...
Jan 24, 2016 | Washing Machines
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
How you open a maytag ensignia washer
The older models had screws at the base to remove. The newest ones have spring clips instead of screws1c7ff10.jpgthis is a dryer but basically you washer fron panel comes off like this when you release the spring clips on each side with a simple putty knife.
May 12, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Washing Machines Logo
228 people viewed this question
Dan Webster
Dan Webster
Sal De
