Question about Maytag Neptune MAH5500B Front Load Washer
We have clogged inlet valve screens. How do I remove my neptunes inlet valve screens so the water can flow into the washer to wash and rinse the clothes? There are two blue hose connectors on the machine and I am not sure if they come off so I can clean the fliters?
    Brigadier General:
  • 6,277 Answers
Turn the taps off and unscrew the hoses, noting which goes where. The fine filters are just inside the 'ports' and should be carefully extracted for cleaning ;-0)
Good luck,
John C
Posted on Mar 25, 2011
Maytag neptune MAH5500BWQ hot water fill runs slow
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Apr 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
What does F20 on the washer mean?
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Whirlpool duet washer LF error
LF error means "Long Fill". Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the LF error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Nov 24, 2012 | Washing Machines
I have a kenmore elite and the code f20 error keeps coming on and it will not get warm
Nov 04, 2012 | Washing Machines
Error f-20 only in the wash cycle
Hi Valleri:
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | Kenmore HE2 Plus Front Load Washer
Clogged inlet screen nf what do I do
rohl521 has you going in the right direction a couple of Pic's to help out but. Please vote for him if the inlet screen is the issue. Just curious the wash tub will fill with a other water selection correct?..........Rich
Jun 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Cold water dribbles in rinse cycle, hot and warm water fine
If you check the warm water flow you'll likely find it is HOT...and not warm. Check the faucet end of hose to see if screen is clogged. Should be screened washer with the dome portion of the screen facing out at you. Remove it and clean with brush to remove grit or scale from screen. If you find nothing there you need to replace the water fill valve located at the other end of the hoses. Good Luck
Aug 23, 2009 | Kenmore 22422 Top Load Washer
Washer will not rinse
SOUNDS LIKE THE INLET VALVE IS CLOGGED OR INOP. THIS CAN BE A NIGHTMARE TO REPLACE, BUT DON'T TRY TO CLEAN IT, JUST REPLACE IT. TRY FILLING FOR WASH WITH COLD ONLY TO CONFIRM. IF NO WATER FLOWS, REPLACE INLET VALVE.
Jan 28, 2009 | GE WSM2420T Top Load Stacked Washer /...
Maytag Neptune MAH5500B Front Load Washer Logo
321 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
