Washing machine working and after a while stops and shows message f-5
    Brigadier General:
  • 6,277 Answers
Unfortunately you have forgotten to mention the make and model so I'm having to guess what the code means- different makes, models, codes! I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
    Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
    Feb 09, 2015 | Washing Machines
    My washing machine fisher paykel mw511 stopped working and now only beeps and show red light on spin. But don't spin or wash clothes
    Is this the same company that makes Fisher-Price Toys?
    I thought so, well you get what you pay for! OK most machines have some Reset function process. Most work by unplugging the machine for 5-10 minutes (computer to reset) then plug it back in. You should get a prompt/ audio or text message (if there is a window) that alerts you that the machine is resetting itself. Then just follow by testing a Light load setting so you do not have to wait around a long time. IF...This does NOT work. THEN...My Friend...You have a BAD control board. Which is like a computer board. And those are EXPENSIVE! $200-$400. So then it becomes economics. How old is the machine 5+ yrs? Buy another Machine
    Mar 15, 2014 | Washing Machines
    Ac voltage become hihg or low when start ifb washing machine
    We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
    Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
    Sep 30, 2012 | IFB Washing Machines
    Hello i am repair man . i have a washing machine model aeg 76800 machine take a program correctly and start but after 5 second stop it please help me quicly thank you
    when it stops do you still have power to the front panel if there is no power to the panel then you would have a bad connection to one of the control boards. are there any error codes showing when the unit does stop such as flashing lights or an exact er code have you checked the door switch? if the door switch does not work the unit will start then stop immediatley message me back with your finds thanks Rick
    Apr 24, 2011 | AEG L76800 Front Load Washer
    Starts to wash and it stops and i have E 2.
    he e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
    To fix you must do a master reset of the washing machine.
    1. Close the door and make sure the dial is pointing to the "OFF" function
    2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
    3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
    4. Release the button and turn the dial back to the "Off" function.
    5. Select any program and the message should not be appearing
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Apr 11, 2011 | Bosch WFMC 3200 Front Load Washer
    Sud message Bosch washing machine
    ur using too much soap rinse and spin and use less soapwhen u wash
    Feb 19, 2010 | Bosch Washing Machines
    Samsung washer
    When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
    1. Turn off the water source to the washing machine.
    2. Unscrew the hose from the back of the washing machine.
    3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
    4. Push the filter back into place.
    5. Screw the hose back onto the washing machine.
    6. Turn on the faucet and make sure the connections are watertight.
    Also, please check the following:
    • Make sure the source water faucet is turned on.
    • Check the water pressure.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jan 28, 2009 | Samsung WF337AA Front Load Washer
    Washing Machines Logo
    12 people viewed this question
    Top Washing Machines Experts
