Question about Moen 24 In. Towel Bar...
There is no set screw--how do I remove towel bar?
  • 14575 Answers
SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Posted on Apr 18, 2010
  • 634 Answers
SOURCE: how do I remove the towel bar from the wall?
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
Posted on Jul 17, 2009
  • 454 Answers
SOURCE: My Brantford towel bar is loose. How do I remove
There are some tiny screws under the posts. Loosen them and lift the post off of its mount.
Posted on Aug 03, 2010
  • 17 Answers
SOURCE: How to remove towel bars and hooks from wall. No
There is a very tiny allen screw on the mounting hardware connected to the wall it is almost invisible. If not there try sliding mounted hardware up or down it should be on a mounting plate
Posted on Sep 24, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: This be a stupid question but I cant figure it
Sorry to read about your problem, I hope this helps you out.
remove the setscrew.. your paint must be holding it on...put a knife and pry a little
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 05, 2011
Testimonial: "I like the look of this towel bar but they really need some QC. Appreciate the help"
How to remove a towel bar with slot in bottom no set screw
Inside the slot there is a tiny set screw May be slotted head or allen screw .
Aug 19, 2014 | Moen 24 In. Towel Bar...
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
How do i remove a towel bar that does not have a set screw on the flange cover?
I think you grab hold of the rosette closest to the wall and spin it off, it should expose the set screw. If that isn't it, one of those things will turn. Try a few different spots. hope this helps.
Mar 20, 2011 | Moen 24 In. Towel Bar...
I need to remove a Moen towel bar. It has a tab under the bottom but I dont know what to do
There should be a "set-screw" (a very small screw) at the bottom of base (fat part) of the towel bar. It screws in to hold the fat part of the bar to the "tab". Loosen the screw by turning it counter-clock-wise. Once loose, the towel bar will lift off the tab. Be careful not to lose the screw!
Feb 21, 2011 | Moen YB8086 Mason Towel Ring Bathroom...
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
How to remove towel bars and hooks from wall. No set screw visible. We did not install them.
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Sep 23, 2010 | Moen 24 In. Towel Bar...
Aug 03, 2010 | Moen YB2218CH Brantford 18'' Towel Bar In...
My towel bar is coming off of the wall and I need to tighten it to the wall. How do I do this?
Towel bars usually have a base that attaches to the wall with a screw. To expose the screw, you must loosen and or remove a small screw on the underside of the mounts. Once the screw is exposed just tighten it.
Jul 29, 2010 | Moen 24 In. Towel Bar...
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
Moen 24 In. Towel Bar... Logo
1,814 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
