Question about Hotpoint Washing Machines
The display panle lights are flikering and hard to read, do i need bulbs or a new panle on wt960g
  • Hotpoint Master
  • 3,463 Answers
Hi.
If you can, remove and refit the nleads going to the display module, if this does not cure the fault, then it is going to mean a new board as you cannot repair a flickering display, due to the way the board is designed.
Posted on Mar 25, 2011
Amana front loading washer won't run after power outage. Panle does light up.
Possible that the program controller unit has failed if there is no display or power in the indication. You will need to remove panel to check on the fuse and if the new fuse fails it is possible there are error or hardware failure within the board.
Please remove and check the power panel for shorted drive, rectifier or capacitor, if not the panel must be replaced.
Jul 04, 2012 | Amana Washing Machines
The handle broke off on my 2003 jeep grand cherokee laredo liftgate. how can i open it now? i can't find anything on the inside in the back and my tail light is out.
You will need to remove the interior panle from the loft gate to axess the latch
there is 4 screws along the bottom of the panle to remove then carfuly pull the panle away from the lift gate there is plastic clips that hold the panle to the gate these may need to be replaced when re installing the panle they can be purchased at the jeep dealer.
now look into the lift gate and you will see where the handle rod conects to the latch lift on this rod and the gate will open
to replace the handle remove the 2 10 mm bolts and disconect the rod from the latch install the new handle and rod to the latch install the 2 10 mm bolts. install the panle and 4 screws
this should cover it
Jul 13, 2010 | 2003 Jeep Grand Cherokee
Screen dull on Janome mc 8000
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light
Janome Memory Craft 8000 LCD Backlight Replacement Kit
Mar 26, 2010 | Janome Memory Craft 5700
Clock and radio lights flicker and dash lights partially out
ITS THE BULBS IN THE DASH, BUT IT SOUNDS LIKE THE ALTENATOR IS GOING BAD IF ALL OTHER LIGHTS FLIKER,IF JUST THE RADIO LIGHTS ITS POSSIBLY JUST THE RADIO LIGHTS GOING OUT
Dec 04, 2009 | 1997 Ford Explorer AWD
My display flikers on and off like you are dimming the display. If you press real hard on the top of the case it will come back on and as soon as you let go it goes dim again. Any clues as to what if might...
Most likely cause is bad solder connections at the display. Remove power remove cover may need to remove front panel and resolder. You will possibly see the cold solder rings around the legs of the display.
Nov 20, 2009 | Car Audio & Video
Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Mar 15, 2009 | Sharp Microwave Ovens
My Westinghouse monitor fliker for 1 sec and dont diaplay anythin
Make sure all cables are tight if that doesn't work you need to put it in the shop if its still under warranty if not you need a new one
Mar 10, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Washing Machines Logo
252 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
