I have an old kenmore washer, on which I cannot find the model number. It needs a new drive belt. The only information that I have is that it is marked as a Kenmore Heavy Duty 80, and inside the door is the number "Stylemaster 902202". Does anybody know where I can find the model number, and does anyone know if parts are still available? We purchased the washer from the previous home owners in 1989, so the washer is older than that. Any ideas?
    Novelist:
  • 111 Answers
Go to a local Sears or Whirlpool store and tell them you have an old "belt drive" Kenmore washer that needs a new belt. All of these were built by Whirlpool Corporation and I believe used a common belt.
Good luck.
Posted on Mar 25, 2011
Need to replace the drive belt (I think!) on a Whirlpool washer model# 110.20912 990. The agitator won't turn but I can hear the motor run. Please tell me how to replace the belt. Thank you!!!
According to the model number you provided, there is not a belt on your machine. Probably what has broken is the coupler between the motor and the transmission. http www searspartsdirect com Kenmore Washer Parts Model 11020912990 0582...
Look at part # 13 the coupler. Hope this helps!
Feb 17, 2015 | Whirlpool Washing Machines
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washing machine spinning function is not drying clothes enough. Seems to work irratically. If I physically start spinning it, it will start to work.
This model washer does NOT have a drive belt. It uses a motor coupling in place of a drive belt and is reffered to as a "direct-drive" system.
The problem you are experiencing is usually caused by a worn gearcase assembly (transmission). If you wish to pursue this repair on your own, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3576575-replacing_a_gearcase_on_whirlpool_manufa
Replacement parts can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost varies, so shop and compare. The first three websites I listed also have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. NOTE: The Sears website will sometimes offer a refurbished gearcase for about half the price. The part number will have the letter "R" at the end.
This is not a difficult repair, but the cost averages about $150. It's still cheaper to purchase and replace the gearcase rather than buying a new washer. However, many consumers will base their decisions on whether or not to repair an applaince based on the age. To determine how old your washer is, you need to refer to the SERIAL NUMBER. The following link explains how to determine the date of manufacture on a Whirlpool manufactured appliance:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
These washers are generally the simplest to repair and last about 15 to 20 years.
If you have any questions about how to determine the age of your appliance, or have any questions about repairs, please post back and let me know. I hope you find this information helpful. Please include your MODEL NUMBER when posting questions.
Mar 29, 2010 | Kenmore Washing Machines
How do I replace the belt on my Kenmore top loading washing machine?
  1. Turn off the washer and unplug it.
  2. Lay the washer on its side so that you can get underneath it.
  3. Remove the old belt by rotating the pulleys that hold it while pulling the belt off of them.
  4. Find the markings on the belt that indicate its model number.
  5. Use this model number to order a new belt from an appliance store.
  6. Attach the new belt by placing it over the pulleys while slowly rotating them.
  7. Return the washer to the upright position and plug it back in.
Jan 25, 2010 | Kenmore Washing Machines
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Belt replacement on kenmore washer
One of the transmission bolts has to be removed to be able to remove the 1" spacer . You also have to turn the pulley which moves the wig-wag to move the glide foreward to drop the shaft of the drive. Very difficult unless you've done it before .
Jul 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
May 20, 2009 | Kenmore 24902 Top Load Washer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
170 people viewed this question
Top Washing Machines Experts
