Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Washer will not spin. cycle timer has been replaced.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Here is a link to the part.
Posted on Mar 25, 2011
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I hae a Whirlpool LSR8233EQ1 Top loading washer.
If you can catch it running while in the spin cycle but not spinning ( put a butter knife or screwdriver in the lid switch hole ) and wiggle the timer knob . If it starts spinning during this process , the timer needs replaced . Sometimes though , when a washer does everything BUT spin and you hear the motor running , the transmission is the problem .
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not engage in final spin cycle.
the timer switch is defective...contacts that activate the final spin cycle is probably corroded or burnt up bad enough that it will not make good enough connection to activate the cycle....I usually take the timer switches apart to clean them but unless you know how to yourself, I suggest you just have the timer switch replaced
Aug 15, 2009 | Frigidaire GLTF2940F Front Load Washer
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Your neutral drain is not locking in.
Let the timer advance to the final spin cycle. Once there it should have about a 5 second pause and the transmission spin gears will lock in. If no pause replace the timer. If you have the pause and still no spin replace the transmission.
My bet is on the timer.
Apr 01, 2009 | Whirlpool WTW5200S Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
